EXTERNAL: Re: MatGetArray() not supporting Mat type mpiaij.
Wed Jun 4 11:23:43 CDT 2008
On Wed, Jun 4, 2008 at 10:15 AM, Stephen R Ball
<Stephen.R.Ball at awe.co.uk> wrote:
> I am using PETSc via the Fortran interface. I don't think MatGetOwnershipRanges() is available via Fortran.
As Barry noted, you can use MatGetOwnershipRange()
  Matt
> From: owner-petsc-users at mcs.anl.gov [mailto:owner-petsc-users at mcs.anl.gov] On Behalf Of Dave May
> Sent: 04 June 2008 13:43
> To: petsc-users at mcs.anl.gov
> Subject: EXTERNAL: Re: EXTERNAL: Re: MatGetArray() not supporting Mat type mpiaij.
> You could use MatGetOwnershipRanges()
> http://www-unix.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-current/docs/manualpages/Mat/MatGetOwnershipRanges.html
> and then traverse the list "ranges[]" to determine which rank owns the global row number of interest.
> Cheers,
>     Dave
> On Wed, Jun 4, 2008 at 9:33 PM, Stephen R Ball <Stephen.R.Ball at awe.co.uk> wrote:
> Ok, I am looking into using MatGetRow(). However this requires the
> global row number for input. I was looking to use MatGetOwnershipRange()
> to obtain the range of global row numbers owned by each processor but
> the documentation states that this routine assumes that the matrix is
> laid out with the first n1 rows on the first processor, the next n2 rows
> on the second, etc and that for certain parallel layouts this range may
> not be well defined.
> This is the case for me. Do you have a routine where I can specify a
> global row number and it will tell me the rank of the processor that
> owns it? This is to ensure that MatGetRow() only gets called by the
> owner processor for each global row number.
> Regards
> Stephen
> -----Original Message-----
> [mailto:owner-petsc-users at mcs.anl.gov] On Behalf Of Matthew Knepley
> Sent: 03 June 2008 15:29
> Subject: EXTERNAL: Re: MatGetArray() not supporting Mat type mpiaij.
> On Tue, Jun 3, 2008 at 8:11 AM, Stephen R Ball
>> Hi
>> I have been trying to extract an array containing the local matrix
>> values using MatGetArray() via the Fortran interface but get the error
>> message that Mat type mpiaij is not supported with this routine. All I
>> want to do is to extract the local matrix values so that I can output
>> them to file in the format I want rather than via use of the MatView()
>> routine. Can you suggest a way of how I can go about extracting the
>> local matrix values?
> This is no "local matrix". The Mat interface is supposed to be data
> structure
> neutral so we can optimize for different architectures. If you want the
> values
> directly, I would use MatGetRow() for each row.
>  Matt
>> Thanks
>> Stephen
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
-- Norbert Wiener
