Poor performance with BoomerAMG?
Fri Feb 15 11:13:28 CST 2008
   Run with the DMMG solver with the option -pc_type hypre
What happens? Then run again with the additional option -ksp_type
richardson
Is hypre taking many, many iterations which is causing the slow speed?
I expect there is something wrong with your code that does not use DMMG.
Be careful how you handle boundary conditions; you need to make sure
they have the same scaling as the other equations.
    Barry
On Feb 15, 2008, at 8:36 AM, knutert at stud.ntnu.no wrote:
> Hi Ben,
> Thank you for answering. With gmres and boomeramg I get a run time of
> 2s, so that is much better. However, if I increase the grid size to
> 513x513, I get a run time of one minute. With richardson, it fails
> to converge.
> LU gives 6 seconds, CG and ICC gives 7s, and the DMMG solver 3s for
> the 513x513 problem.
> When using the DMMG framework, I just used the default solvers.
> I use the Galerkin process to generate the coarse matrices for
> the multigrid cycle.
> Best,
> Knut
> Siterer Ben Tay <zonexo at gmail.com>:
>> Hi Knut,
>> I'm currently using boomeramg to solve my poisson eqn too. I'm
>> using it
>> on my structured C-grid. I found it to be faster than LU,
>> especially as
>> the grid size increases. However I use it as a preconditioner with
>> GMRES as the solver. Have you tried this option? Although it's
>> faster,
>> the speed increase is usually less than double. It seems to be
>> worse if
>> there is a lot of stretching in the grid.
>> Btw, your mention using the DMMG framework and it takes less than a
>> sec. What solver or preconditioner did you use? It's 4 times faster
>> than GMRES...
>> thanks!
>>> Hello,
>>> I am trying to use the hypre multigrid solver to solve a Poisson
>>> equation.
>>> However, on a test case with grid size 257x257 it takes 40
>>> seconds  to converge
>>> on one processor when I run with
>>> ./run -ksp_type richardson -pc_type hypre -pc_type_hypre boomeramg
>>> Using the DMMG framework, the same problem takes less than a second,
>>> and the default gmres solver uses only four seconds.
>>> Am I somehow using the solver the wrong way, or is this
>>> performance  expected?
>>> Regards
>>> Knut Erik Teigen
