sub_pc lu zero pivot
Andrew T Barker Andrew.Barker at Colorado.EDU
Fri Feb 8 11:46:09 CST 2008
For my code on a single processor, using the options
-ksp_type gmres -pc_type lu
works fine, but
-ksp_type gmres -pc_type asm -sub_pc_type lu
produces a zero pivot.  On one processor I would expect these two to be identical, and in fact when I print out the asm submatrices (there is only one) in the second case and the original matrix in the first case, they are identical.  Even stranger is that
-ksp_type gmres -pc_type lu -sub_pc_type lu
also produces a zero pivot.  I would expect it to ignore the sub_pc in this case.
Thanks for any help,
Andrew
Andrew T. Barker
andrew.barker at colorado.edu
Applied Math Department
University of Colorado, Boulder
526 UCB, Boulder, CO 80309-0526
