PCGetType question
Lisandro Dalcin dalcinl at gmail.com
Fri Feb 8 07:52:46 CST 2008
On 2/8/08, Vijay S. Mahadevan <vijay.m at gmail.com> wrote:
> PetscTruth isshell ;
> PetscTypeCompare((PetscObject)pc, PCSHELL, &isshell);
> PetscPrintf(PETSC_COMM_SELF, " PETSC_IS_SHELL = %D", isshell) ;
> Result: The isshell variable is always false even when I set –pc_type shell
> option. Why ?
Did you call PCSetFromOptions (or KSPSetFromOptions) before calling
PetscTypeCompare()? If not, the option '-pc_type' will not be used
> Method 2:
> PCType currpcType ;
> ierr = PCGetType(pc, &currpcType) ;
> if(currpcType == PCSHELL)
>     isshell = PETSC_TRUE ;
> Result: Again, the isshell variable is always false even when I set –pc_type
> shell option. Also, my currpcType string is a null string.
PCType is a 'const char*', so you should never compare that with '=='
opertor!!. Again, if you got a null pointer from PCGetType(), my guess
is that you forgot to call XXXSetFromOptions, where XXX is PC, or a
KSP object containing it, or a SNES cointaing the KSP in turn
containing the PC.
Lisandro Dalcín
Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
PTLC - Güemes 3450, (3000) Santa Fe, Argentina
Tel/Fax: +54-(0)342-451.1594
