how to inverse a sparse matrix in Petsc?
Tue Feb 5 21:21:46 CST 2008
On Feb 5, 2008, at 8:48 PM, Ben Tay wrote:
> Thank you Barry for your enlightenment. I'll just continue to use
> BoomerAMG for the poisson eqn. I'll also check up on FFTW. Last
> time, I recalled that there seemed to be some restrictions for FFT
> on solving poisson eqn. It seems that the grids must be constant in
> at least 1 dimension.
    Yes. Then it decouples into a bunch of tridiagonal solves;
Basically if you can do separation of variables you can
use FFTs.
    Barry
> I wonder if that is true? If that's the case, then it's not possible
> for me to use it, although it's a constant coefficient Poisson
> operator with Neumann or Dirchelet boundary conditions.
> thank you.
> Barry Smith wrote:
>> On Feb 5, 2008, at 8:04 PM, Ben Tay wrote:
>>> Hi Lisandro,
>>> I'm using the fractional step mtd to solve the NS eqns as well.
>>> I've tried the direct mtd and also boomerAMG in solving the
>>> poisson eqn. Experience shows that for smaller matrix, direct mtd
>>> is slightly faster but if the matrix increases in size, boomerAMG
>>> is faster. Btw, if I'm not wrong, the default solver will be
>>> GMRES. I've also tried using the "Struct" interface solely under
>>> Hypre. It's even faster for big matrix, although the improvement
>>> doesn't seem to be a lot. I need to do more tests to confirm though.
>>> I'm now doing 2D simulation with 1400x2000 grids. It's takes quite
>>> a while to solve the eqns. I'm wondering if it'll be faster if I
>>> get the inverse and then do matrix multiplication. Or just calling
>>> KSPSolve is actually doing something similar and there'll not be
>>> any speed difference. Hope someone can enlighten...
>>> Thanks!
>>   Ben,
>>     Forming the inverse explicitly will be a complete failure.
>> Because it is dense it will have (1400x2000)^2 values and
>> each multiply will take 2*(1400x2000)^2 floating point operations,
>> while boomerAMG should take only O(1400x2000).
>>     BTW: if this is a constant coefficient Poisson operator with
>> Neumann or Dirchelet boundary conditions then
>> likely a parallel FFT based algorithm would be fastest. Alas we do
>> not yet have this in PETSc. It looks like FFTW finally
>> has an updated MPI version so we need to do the PETSc interface for
>> that.
>>   Barry
>>> Lisandro Dalcin wrote:
>>>> Ben, some time ago I was doing some testing with PETSc for solving
>>>> incompressible NS eqs with fractional step method. I've found
>>>> that in
>>>> our software and hardware setup, the best way to solve the pressure
>>>> problem was by using HYPRE BoomerAMG. This preconditioner usually
>>>> have
>>>> some heavy setup, but if your Poison matrix does not change, then
>>>> the
>>>> sucessive solves at each time step are really fast.
>>>> If you still want to use a direct method, you should use the
>>>> combination '-ksp_type preonly -pc_type lu' (by default, this will
>>>> only work on sequential mode, unless you build PETSc with an
>>>> external
>>>> package like MUMPS). This way, PETSc computes the LU factorization
>>>> only once, and at each time step, the call to KSPSolve end-up only
>>>> doing the triangular solvers.
>>>> The nice thing about PETSc is that, if you next realize the
>>>> factorization take a long time (as it usually take in big
>>>> problems),
>>>> you can switch BoomerAMG by only passing in the command line
>>>> '-ksp_type cg -pc_type hypre -pc_hypre_type boomeramg'. And that's
>>>> all, you do not need to change your code. And more, depending on
>>>> your
>>>> problem you can choose the direct solvers or algebraic multigrid as
>>>> you want, by simply pass the appropriate combination options in the
>>>> command line (or a options file, using the -options_file option).
>>>> Please, if you ever try HYPRE BoomerAMG preconditioners, I would
>>>> like
>>>> to know about your experience.
>>>> Regards,
>>>> On 2/5/08, Ben Tay <zonexo at gmail.com> wrote:
>>>>> Hi everyone,
>>>>> I was reading about the topic abt inversing a sparse matrix. I
>>>>> have to
>>>>> solve a poisson eqn for my CFD code. Usually, I form a system of
>>>>> linear
>>>>> eqns and solve Ax=b. The "A" is always the same and only the "b"
>>>>> changes
>>>>> every timestep. Does it mean that if I'm able to get the inverse
>>>>> matrix
>>>>> A^(-1), in order to get x at every timestep, I only need to do a
>>>>> simple
>>>>> matrix multiplication ie x=A^(-1)*b ?
>>>>> Hi Timothy, if the above is true, can you email me your Fortran
>>>>> code
>>>>> template? I'm also programming in fortran 90. Thank you very much
>>>>> Regards.
>>>>> Timothy Stitt wrote:
>>>>>> Yes Yujie, I was able to put together a parallel code to invert a
>>>>>> large sparse matrix with the help of the PETSc developers. If
>>>>>> you need
>>>>>> any help or maybe a Fortran code template just let me know.
>>>>>> Best,
>>>>>> Tim.
>>>>>> Waad Subber wrote:
>>>>>>> Hi
>>>>>>> There was a discussion between Tim Stitt and petsc developers
>>>>>>> about
>>>>>>> matrix inversion, and it was really helpful. That was in last
>>>>>>> Nov.
>>>>>>> You can check the emails archive
>>>>>>> http://www-unix.mcs.anl.gov/web-mail-archive/lists/petsc-users/2007/11/threads.html
>>>>>>> Waad
>>>>>>> */Yujie <recrusader at gmail.com>/* wrote:
>>>>>>>   what is the difference between sequantial and parallel AIJ
>>>>>>> matrix?
>>>>>>>   Assuming there is a matrix A, if
>>>>>>>   I partitaion this matrix into A1, A2, Ai... An.
>>>>>>>   A is a parallel AIJ matrix at the whole view, Ai
>>>>>>>   is a sequential AIJ matrix? I want to operate Ai at each node.
>>>>>>>   In addition, whether is it possible to get general inverse
>>>>>>> using
>>>>>>>   MatMatSolve() if the matrix is not square? Thanks a lot.
>>>>>>>   Regards,
>>>>>>>   Yujie
>>>>>>>   On 2/4/08, *Barry Smith* <bsmith at mcs.anl.gov
>>>>>>>   <mailto:bsmith at mcs.anl.gov>> wrote:
>>>>>>>           For sequential AIJ matrices you can fill the B matrix
>>>>>>> with the
>>>>>>>       identity and then use
>>>>>>>       MatMatSolve().
>>>>>>>           Note since the inverse of a sparse matrix is dense
>>>>>>> the B
>>>>>>>       matrix is
>>>>>>>       a SeqDense matrix.
>>>>>>>           Barry
>>>>>>>       On Feb 4, 2008, at 12:37 AM, Yujie wrote:
>>>>>>>       > Hi,
>>>>>>>       > Now, I want to inverse a sparse matrix. I have browsed
>>>>>>> the
>>>>>>>       manual,
>>>>>>>       > however, I can't find some information. could you give
>>>>>>> me
>>>>>>>       some advice?
>>>>>>>       > thanks a lot.
>>>>>>>       > Regards,
>>>>>>>       > Yujie
>>>>>>> Looking for last minute shopping deals? Find them fast with
>>>>>>> Yahoo!
>>>>>>> Search.
>>>>>>> <http://us.rd.yahoo.com/evt=51734/*http://tools.search.yahoo.com/newsearch/category.php?category=shopping
