how to inverse a sparse matrix in Petsc?
Ben Tay zonexo at gmail.com
Tue Feb 5 20:48:38 CST 2008
Thank you Barry for your enlightenment. I'll just continue to use
BoomerAMG for the poisson eqn. I'll also check up on FFTW. Last time, I
recalled that there seemed to be some restrictions for FFT on solving
poisson eqn. It seems that the grids must be constant in at least 1
dimension. I wonder if that is true? If that's the case, then it's not
possible for me to use it, although it's a constant coefficient Poisson
operator with Neumann or Dirchelet boundary conditions.
thank you.
Barry Smith wrote:
> On Feb 5, 2008, at 8:04 PM, Ben Tay wrote:
>> Hi Lisandro,
>> I'm using the fractional step mtd to solve the NS eqns as well. I've
>> tried the direct mtd and also boomerAMG in solving the poisson eqn.
>> Experience shows that for smaller matrix, direct mtd is slightly
>> faster but if the matrix increases in size, boomerAMG  is faster.
>> Btw, if I'm not wrong, the default solver will be GMRES. I've also
>> tried using the "Struct" interface solely under Hypre. It's even
>> faster for big matrix, although the improvement doesn't seem to be a
>> lot. I need to do more tests to confirm though.
>> I'm now doing 2D simulation with 1400x2000 grids. It's takes quite a
>> while to solve the eqns. I'm wondering if it'll be faster if I get
>> the inverse and then do matrix multiplication. Or just calling
>> KSPSolve is actually doing something similar and there'll not be any
>> speed difference. Hope someone can enlighten...
>> Thanks!
>    Ben,
>      Forming the inverse explicitly will be a complete failure.
> Because it is dense it will have (1400x2000)^2 values and
> each multiply will take 2*(1400x2000)^2 floating point operations,
> while boomerAMG should take only O(1400x2000).
>      BTW: if this is a constant coefficient Poisson operator with
> Neumann or Dirchelet boundary conditions then
> likely a parallel FFT based algorithm would be fastest. Alas we do not
> yet have this in PETSc. It looks like FFTW finally
> has an updated MPI version so we need to do the PETSc interface for that.
>    Barry
>> Lisandro Dalcin wrote:
>>> Ben, some time ago I was doing some testing with PETSc for solving
>>> incompressible NS eqs with fractional step method. I've found that in
>>> our software and hardware setup, the best way to solve the pressure
>>> problem was by using HYPRE BoomerAMG. This preconditioner usually have
>>> some heavy setup, but if your Poison matrix does not change, then the
>>> sucessive solves at each time step are really fast.
>>> If you still want to use a direct method, you should use the
>>> combination '-ksp_type preonly -pc_type lu' (by default, this will
>>> only work on sequential mode, unless you build PETSc with an external
>>> package like MUMPS). This way, PETSc computes the LU factorization
>>> only once, and at each time step, the call to KSPSolve end-up only
>>> doing the triangular solvers.
>>> The nice thing about PETSc is that, if you next realize the
>>> factorization take a long time (as it usually take in big problems),
>>> you can switch BoomerAMG by only passing in the command line
>>> '-ksp_type cg -pc_type hypre -pc_hypre_type boomeramg'. And that's
>>> all, you do not need to change your code. And more, depending on your
>>> problem you can choose the direct solvers or algebraic multigrid as
>>> you want, by simply pass the appropriate combination options in the
>>> command line (or a options file, using the -options_file option).
>>> Please, if you ever try HYPRE BoomerAMG preconditioners, I would like
>>> to know about your experience.
>>> Regards,
>>> On 2/5/08, Ben Tay <zonexo at gmail.com> wrote:
>>>> Hi everyone,
>>>> I was reading about the topic abt inversing a sparse matrix. I have to
>>>> solve a poisson eqn for my CFD code. Usually, I form a system of
>>>> linear
>>>> eqns and solve Ax=b. The "A" is always the same and only the "b"
>>>> changes
>>>> every timestep. Does it mean that if I'm able to get the inverse
>>>> matrix
>>>> A^(-1), in order to get x at every timestep, I only need to do a
>>>> simple
>>>> matrix multiplication ie x=A^(-1)*b ?
>>>> Hi Timothy, if the above is true, can you email me your Fortran code
>>>> template? I'm also programming in fortran 90. Thank you very much
>>>> Regards.
>>>> Timothy Stitt wrote:
>>>>> Yes Yujie, I was able to put together a parallel code to invert a
>>>>> large sparse matrix with the help of the PETSc developers. If you
>>>>> need
>>>>> any help or maybe a Fortran code template just let me know.
>>>>> Best,
>>>>> Tim.
>>>>> Waad Subber wrote:
>>>>>> Hi
>>>>>> There was a discussion between Tim Stitt and petsc developers about
>>>>>> matrix inversion, and it was really helpful. That was in last Nov.
>>>>>> You can check the emails archive
>>>>>> http://www-unix.mcs.anl.gov/web-mail-archive/lists/petsc-users/2007/11/threads.html
>>>>>> Waad
>>>>>> */Yujie <recrusader at gmail.com>/* wrote:
>>>>>>    what is the difference between sequantial and parallel AIJ
>>>>>> matrix?
>>>>>>    Assuming there is a matrix A, if
>>>>>>    I partitaion this matrix into A1, A2, Ai... An.
>>>>>>    A is a parallel AIJ matrix at the whole view, Ai
>>>>>>    is a sequential AIJ matrix? I want to operate Ai at each node.
>>>>>>    In addition, whether is it possible to get general inverse using
>>>>>>    MatMatSolve() if the matrix is not square? Thanks a lot.
>>>>>>    Regards,
>>>>>>    Yujie
>>>>>>    On 2/4/08, *Barry Smith* <bsmith at mcs.anl.gov
>>>>>>    <mailto:bsmith at mcs.anl.gov>> wrote:
>>>>>>            For sequential AIJ matrices you can fill the B matrix
>>>>>> with the
>>>>>>        identity and then use
>>>>>>        MatMatSolve().
>>>>>>            Note since the inverse of a sparse matrix is dense the B
>>>>>>        matrix is
>>>>>>        a SeqDense matrix.
>>>>>>            Barry
>>>>>>        On Feb 4, 2008, at 12:37 AM, Yujie wrote:
>>>>>>        > Hi,
>>>>>>        > Now, I want to inverse a sparse matrix. I have browsed the
>>>>>>        manual,
>>>>>>        > however, I can't find some information. could you give me
>>>>>>        some advice?
>>>>>>        > thanks a lot.
>>>>>>        > Regards,
>>>>>>        > Yujie
>>>>>> Looking for last minute shopping deals? Find them fast with Yahoo!
>>>>>> Search.
>>>>>> <http://us.rd.yahoo.com/evt=51734/*http://tools.search.yahoo.com/newsearch/category.php?category=shopping>
