assembly
Mon Feb 4 10:47:44 CST 2008
On Feb 4, 2008 10:41 AM, Thomas Geenen <geenen at gmail.com> wrote:
> On Feb 3, 2008 8:51 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> >     Hmmm, are you saying the first round of setting values still
> > takes much longer then the second round?
> yes
> >Or is it the time
> > in MatAssemblyBegin() much longer the first time?
> >    The MatAssembly process has one piece of code that's
> > work is order n*size; where n is the stash size and size is the
> > number of processes, all other work is only order n.
> >     Could you send the -log_summary output?
> the timing is cumulative i guess?
> in between these two solves i solve a smaller system for which i do
> not include the timing.
I ma having a little trouble reading this. I think the easiest thing to do
is wrap the two section of code in their own sections:
PetscLogStageRegister(&stage1, "First assembly");
PetscLogStageRegister(&stage2, "Second assembly");
PetscLogStagePush(stage1);
<code for first assembly>
PetscLogStagePop();
PetscLogStagePush(stage2);
<code for second assembly>
PetscLogStagePop();
Then we can also get a look at how many messages are sent
and how big they are.
     Matt
> run 1
>                          Max       Max/Min        Avg      Total
> Time (sec):           2.154e+02      1.00001   2.154e+02
> Objects:              2.200e+01      1.00000   2.200e+01
> Flops:                0.000e+00      0.00000   0.000e+00  0.000e+00
> Flops/sec:            0.000e+00      0.00000   0.000e+00  0.000e+00
> MPI Messages:         1.750e+01      1.25000   1.633e+01  9.800e+01
> MPI Message Lengths:  3.460e+06      1.29903   1.855e+05  1.818e+07
> MPI Reductions:       4.167e+00      1.00000
> Flop counting convention: 1 flop = 1 real number operation of type
> (multiply/divide/add/subtract)
>                             e.g., VecAXPY() for real vectors of length
> N --> 2N flops
>                             and VecAXPY() for complex vectors of
> length N --> 8N flops
> Summary of Stages:   ----- Time ------  ----- Flops -----  ---
> Messages ---  -- Message Lengths --  -- Reductions --
>                         Avg     %Total     Avg     %Total   counts
> %Total     Avg         %Total   counts   %Total
>  0:      Main Stage: 2.1537e+02 100.0%  0.0000e+00   0.0%  9.800e+01
> 100.0%  1.855e+05      100.0%  2.500e+01 100.0%
> See the 'Profiling' chapter of the users' manual for details on
> interpreting output.
> Phase summary info:
>    Count: number of times phase was executed
>    Time and Flops/sec: Max - maximum over all processors
>                        Ratio - ratio of maximum to minimum over all processors
>    Mess: number of messages sent
>    Avg. len: average message length
>    Reduct: number of global reductions
>    Global: entire computation
>    Stage: stages of a computation. Set stages with PetscLogStagePush()
> and PetscLogStagePop().
>       %T - percent time in this phase         %F - percent flops in this phase
>       %M - percent messages in this phase     %L - percent message
> lengths in this phase
>       %R - percent reductions in this phase
>    Total Mflop/s: 10e-6 * (sum of flops over all processors)/(max time
>       #                          WARNING!!!                    #
>       #   This code was run without the PreLoadBegin()         #
>       #   macros. To get timing results we always recommend    #
>       #   preloading. otherwise timing numbers may be          #
>       #   meaningless.                                         #
> Event                Count      Time (sec)     Flops/sec
>           --- Global ---  --- Stage ---   Total
>                    Max Ratio  Max     Ratio   Max  Ratio  Mess   Avg
> len Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
> --- Event Stage 0: Main Stage
> MatAssemblyBegin       1 1.0 2.9536e-01 4.0 0.00e+00 0.0 4.2e+01
> 4.2e+05 2.0e+00  0  0 43 98  8   0  0 43 98  8     0
> MatAssemblyEnd         1 1.0 2.1410e+02 1.0 0.00e+00 0.0 2.8e+01
> 8.2e+03 7.0e+00 99  0 29  1 28  99  0 29  1 28     0
> MatZeroEntries         1 1.0 9.3739e-02 5.9 0.00e+00 0.0 0.0e+00
> 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> VecSet                 4 1.0 3.9721e-04 2.2 0.00e+00 0.0 0.0e+00
> Memory usage is given in bytes:
> Object Type          Creations   Destructions   Memory  Descendants' Mem.
>               Matrix     3              0          0     0
>            Index Set     6              6      45500     0
>                  Vec     6              1     196776     0
>          Vec Scatter     3              0          0     0
>    IS L to G Mapping     2              0          0     0
>        Krylov Solver     1              0          0     0
>       Preconditioner     1              0          0     0
> Average time to get PetscTime(): 1.71661e-06
> Average time for MPI_Barrier(): 0.000159979
> Average time for zero size MPI_Send(): 1.29938e-05
> Compiled without FORTRAN kernels
> Compiled with full precision matrices (default)
> sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8
> sizeof(PetscScalar) 8
> Configure run at: Fri Sep 28 23:34:20 2007
> run2
> Time (sec):           2.298e+02      1.00000   2.298e+02
> Objects:              2.600e+02      1.00000   2.600e+02
> Flops:                1.265e+09      1.17394   1.161e+09  6.969e+09
> Flops/sec:            5.505e+06      1.17394   5.054e+06  3.032e+07
> MPI Messages:         1.436e+03      1.20816   1.326e+03  7.956e+03
> MPI Message Lengths:  2.120e+07      1.23141   1.457e+04  1.159e+08
> MPI Reductions:       4.192e+02      1.00000
> N --> 2N flops
>  0:      Main Stage: 2.2943e+02  99.8%  6.9689e+09 100.0%  7.944e+03
> 99.8%  1.457e+04      100.0%  2.230e+02   8.9%
> Phase summary info:
>       #                          WARNING!!!                    #
>       #   meaningless.                                         #
> MatMult              135 1.0 2.0830e+00 1.4 2.30e+08 1.9 2.4e+03
> 1.3e+04 0.0e+00  1 26 30 26  0   1 26 30 26  0   862
> MatMultAdd            40 1.0 3.2598e-01 4.5 2.68e+07 5.7 0.0e+00
> 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0    31
> MatSolve              44 1.0 6.7841e-01 1.7 1.93e+08 1.7 0.0e+00
> 0.0e+00 0.0e+00  0  7  0  0  0   0  7  0  0  0   672
> MatRelax              80 1.0 4.2949e+00 1.6 8.77e+07 1.2 2.2e+03
> 1.3e+04 0.0e+00  1 23 28 26  0   1 23 28 26  0   374
> MatLUFactorSym         1 1.0 7.6739e-02 1.1 0.00e+00 0.0 0.0e+00
> 0.0e+00 1.0e+00  0  0  0  0  0   0  0  0  0  0     0
> MatLUFactorNum         2 1.0 2.9370e+00 1.5 2.53e+08 1.5 0.0e+00
> 0.0e+00 0.0e+00  1 44  0  0  0   1 44  0  0  0  1037
> MatILUFactorSym        1 1.0 6.7334e-01 1.0 0.00e+00 0.0 0.0e+00
> MatAssemblyBegin       7 1.0 7.1652e-01 4.4 0.00e+00 0.0 1.3e+02
> 2.9e+05 8.0e+00  0  0  2 32  0   0  0  2 32  4     0
> MatAssemblyEnd         7 1.0 2.1473e+02 1.0 0.00e+00 0.0 8.4e+01
> 3.2e+03 2.2e+01 93  0  1  0  1  94  0  1  0 10     0
> MatGetRowIJ            2 1.0 1.8899e-03 1.1 0.00e+00 0.0 0.0e+00
> MatGetSubMatrice       1 1.0 3.1915e-02 1.0 0.00e+00 0.0 0.0e+00
> 0.0e+00 3.0e+00  0  0  0  0  0   0  0  0  0  1     0
> MatGetOrdering         2 1.0 1.2184e-02 1.6 0.00e+00 0.0 0.0e+00
> 0.0e+00 4.0e+00  0  0  0  0  0   0  0  0  0  2     0
> MatIncreaseOvrlp       1 1.0 7.6865e-02 1.0 0.00e+00 0.0 1.1e+03
> 2.4e+03 2.0e+01  0  0 13  2  1   0  0 13  2  9     0
> MatZeroEntries         3 1.0 1.0429e-01 4.7 0.00e+00 0.0 0.0e+00
> MAT_GetRedundantMatrix       1 1.0 3.0144e-02 1.2 0.00e+00 0.0 9.0e+01
> 8.0e+04 2.0e+00  0  0  1  6  0   0  0  1  6  1     0
> VecDot                39 1.0 9.0680e-01140.0 2.95e+08191.3 0.0e+00
> 0.0e+00 3.9e+01  0  0  0  0  2   0  0  0  0 17    11
> VecMDot                8 1.0 2.8777e-03 2.8 4.16e+07 3.3 0.0e+00
> 0.0e+00 8.0e+00  0  0  0  0  0   0  0  0  0  4    84
> VecNorm               31 1.0 6.2301e-02 4.2 7.17e+07 5.8 0.0e+00
> 0.0e+00 3.1e+01  0  0  0  0  1   0  0  0  0 14    86
> VecScale              85 1.0 1.7729e-03 1.4 4.94e+08 1.4 0.0e+00
> 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  2138
> VecCopy                4 1.0 6.2108e-04 1.5 0.00e+00 0.0 0.0e+00
> VecSet               139 1.0 3.5934e-03 1.4 0.00e+00 0.0 0.0e+00
> VecAXPY               98 1.0 5.1496e-03 1.3 9.24e+08 1.1 0.0e+00
> 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  4705
> VecAYPX               40 1.0 1.0311e-02 1.4 1.90e+08 1.0 0.0e+00
> 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   969
> VecWAXPY              75 1.0 2.6060e-02 1.4 1.22e+08 1.0 0.0e+00
> 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   618
> VecMAXPY               9 1.0 2.1315e-04 1.6 3.01e+08 1.2 0.0e+00
> 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  1355
> VecAssemblyBegin       4 1.0 1.9898e-03 1.2 0.00e+00 0.0 0.0e+00
> 0.0e+00 1.2e+01  0  0  0  0  0   0  0  0  0  5     0
> VecAssemblyEnd         4 1.0 2.1219e-05 1.2 0.00e+00 0.0 0.0e+00
> VecScatterBegin      267 1.0 1.0224e-01 1.6 0.00e+00 0.0 6.3e+03
> 1.1e+04 0.0e+00  0  0 79 59  0   0  0 79 59  0     0
> VecScatterEnd        267 1.0 7.8653e-0111.3 0.00e+00 0.0 0.0e+00
> KSPGMRESOrthog         4 1.0 3.7677e-03 1.9 4.78e+07 2.4 0.0e+00
> 0.0e+00 1.2e+01  0  0  0  0  0   0  0  0  0  5   141
> KSPSetup               6 1.0 1.0260e-02 1.0 0.00e+00 0.0 0.0e+00
> KSPSolve               2 1.0 7.8238e+00 1.0 1.16e+08 1.2 5.9e+03
> 1.1e+04 8.1e+01  3 70 75 54  3   3 70 75 54 36   622
> PCSetUp                3 1.0 5.1323e+00 1.2 1.29e+08 1.2 1.6e+03
> 9.1e+03 7.3e+01  2 47 20 13  3   2 47 20 13 33   636
> PCSetUpOnBlocks        1 1.0 1.3325e+00 1.0 1.47e+08 1.0 0.0e+00
> 0.0e+00 3.0e+00  1 17  0  0  0   1 17  0  0  1   871
> PCApply               44 1.0 5.7917e+00 1.1 9.60e+07 1.2 4.7e+03
> 1.0e+04 0.0e+00  2 41 59 42  0   2 41 59 42  0   497
>               Matrix    16              0          0     0
>            Index Set    36             29     256760     0
>                  Vec   176             93   16582464     0
>          Vec Scatter    10              0          0     0
>    IS L to G Mapping     4              0          0     0
>        Krylov Solver     6              0          0     0
>       Preconditioner     6              0          0     0
>               Viewer     4              2          0     0
>            Container     2              0          0     0
> Average time to get PetscTime(): 8.10623e-07
> Average time for MPI_Barrier(): 0.000178194
> Average time for zero size MPI_Send(): 1.33117e-05
> OptionTable: -mg_levels_ksp_type richardson
> OptionTable: -mg_levels_pc_sor_omega 1.05
> OptionTable: -mg_levels_pc_type sor
> OptionTable: -pc_ml_PrintLevel 4
> OptionTable: -pc_ml_maxNlevels 2
> OptionTable: -pc_type ml
> >     Barry
> >     The a
> > On Feb 3, 2008, at 6:44 AM, Thomas Geenen wrote:
> > > i call
> > > ierr = MatStashSetInitialSize(A[*seqsolve],stash_size,
> > > stash_size);CHKERRQ(ierr);
> > > with 100 000 000 for the stash size to make sure that's not the
> > > bottleneck
> > > the assemble time remains unchanged however.
> > > nstash in MatAssemblyBegin_MPIAIJ (CPU=0) = 109485
> > > reallocs in MatAssemblyBegin_MPIAIJ =  0
> > > cheers
> > > Thomas
> > > On Saturday 02 February 2008 23:19, Barry Smith wrote:
> > >>    The matstash has a concept of preallocation also. During the first
> > >> setvalues
> > >> it is allocating more and more memory for the stash. In the second
> > >> setvalues
> > >> the stash is large enough so does not require any addition
> > >> allocation.
> > >>    You can use the option -matstash_initial_size <size> to allocate
> > >> enough space
> > >> initially so that the first setvalues is also fast. It does not look
> > >> like there is a way
> > >> coded to get the <size> that you should use. It should be set to the
> > >> maximum nonzeros
> > >> any process has that belongs to other processes. The stash handling
> > >> code is
> > >> in src/mat/utils/matstash.c, perhaps you can figure out how to
> > >> printout with PetscInfo()
> > >> the sizes needed?
> > >>    Barry
> > >> On Feb 2, 2008, at 12:30 PM, Thomas Geenen wrote:
> > >>> On Saturday 02 February 2008 18:33, Hong Zhang wrote:
> > >>>> On Sat, 2 Feb 2008, Thomas Geenen wrote:
> > >>>>> Dear Petsc users,
> > >>>>> I would like to understand what is slowing down the assembly phase
> > >>>>> of my
> > >>>>> matrix. I create a matrix with MatCreateMPIAIJ i make a rough
> > >>>>> guess of
> > >>>>> the number of off diagonal entries and then use a conservative
> > >>>>> value to
> > >>>>> make sure I do not need extra mallocs. (the number of diagonal
> > >>>>> entries is
> > >>>>> exact)
> > >>>>> next i call MatSetValues and MatAssemblyBegin, MatAssemblyEnd.
> > >>>>> The first time i call MatSetValues and MatAssemblyBegin,
> > >>>>> MatAssemblyEnd it takes about 170 seconds
> > >>>>> the second time 0.3 seconds.
> > >>>>> I run it on 6 cpu's and I do fill quit a number of row-entries on
> > >>>>> the
> > >>>>> "wrong" cpu. However thats also the case the second run. I checked
> > >>>>> that there are no additional mallocs
> > >>>>> MatGetInfo info.mallocs=0 both after MatSetValues and after
> > >>>> Run your code with the option '-log_summary' and check which
> > >>>> function
> > >>>> call dominates the execution time.
> > >>> the time is spend in MatStashScatterGetMesg_Private
> > >>>>> the
> > >>>>> "wrong" cpu.
> > >>>> Likely, the communication that sending the entries to the
> > >>>> corrected cpu consume the time. Can you fill the entries in the
> > >>>> correct cpu?
> > >>> the second time the entries are filled on the wrong CPU as well.
> > >>> i am curious about the difference in time between run 1 and 2.
> > >>>> Hong
> > >>>>> cheers
> > >>>>> Thomas
experiments is infinitely more interesting than any results to which
their experiments lead.
-- Norbert Wiener
