assembly
Thomas Geenen geenen at gmail.com
Mon Feb 4 10:41:11 CST 2008
On Feb 3, 2008 8:51 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>     Hmmm, are you saying the first round of setting values still
> takes much longer then the second round?
yes
>Or is it the time
> in MatAssemblyBegin() much longer the first time?
>    The MatAssembly process has one piece of code that's
> work is order n*size; where n is the stash size and size is the
> number of processes, all other work is only order n.
>     Could you send the -log_summary output?
the timing is cumulative i guess?
in between these two solves i solve a smaller system for which i do
not include the timing.
run 1
                         Max       Max/Min        Avg      Total
Time (sec):           2.154e+02      1.00001   2.154e+02
Objects:              2.200e+01      1.00000   2.200e+01
Flops:                0.000e+00      0.00000   0.000e+00  0.000e+00
Flops/sec:            0.000e+00      0.00000   0.000e+00  0.000e+00
MPI Messages:         1.750e+01      1.25000   1.633e+01  9.800e+01
MPI Message Lengths:  3.460e+06      1.29903   1.855e+05  1.818e+07
MPI Reductions:       4.167e+00      1.00000
Flop counting convention: 1 flop = 1 real number operation of type
(multiply/divide/add/subtract)
                            e.g., VecAXPY() for real vectors of length
N --> 2N flops
                            and VecAXPY() for complex vectors of
length N --> 8N flops
Summary of Stages:   ----- Time ------  ----- Flops -----  ---
Messages ---  -- Message Lengths --  -- Reductions --
                        Avg     %Total     Avg     %Total   counts
%Total     Avg         %Total   counts   %Total
 0:      Main Stage: 2.1537e+02 100.0%  0.0000e+00   0.0%  9.800e+01
100.0%  1.855e+05      100.0%  2.500e+01 100.0%
See the 'Profiling' chapter of the users' manual for details on
interpreting output.
Phase summary info:
   Count: number of times phase was executed
   Time and Flops/sec: Max - maximum over all processors
                       Ratio - ratio of maximum to minimum over all processors
   Mess: number of messages sent
   Avg. len: average message length
   Reduct: number of global reductions
   Global: entire computation
   Stage: stages of a computation. Set stages with PetscLogStagePush()
and PetscLogStagePop().
      %T - percent time in this phase         %F - percent flops in this phase
      %M - percent messages in this phase     %L - percent message
lengths in this phase
      %R - percent reductions in this phase
   Total Mflop/s: 10e-6 * (sum of flops over all processors)/(max time
      #                          WARNING!!!                    #
      #   This code was run without the PreLoadBegin()         #
      #   macros. To get timing results we always recommend    #
      #   preloading. otherwise timing numbers may be          #
      #   meaningless.                                         #
Event                Count      Time (sec)     Flops/sec
          --- Global ---  --- Stage ---   Total
                   Max Ratio  Max     Ratio   Max  Ratio  Mess   Avg
len Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
--- Event Stage 0: Main Stage
MatAssemblyBegin       1 1.0 2.9536e-01 4.0 0.00e+00 0.0 4.2e+01
4.2e+05 2.0e+00  0  0 43 98  8   0  0 43 98  8     0
MatAssemblyEnd         1 1.0 2.1410e+02 1.0 0.00e+00 0.0 2.8e+01
8.2e+03 7.0e+00 99  0 29  1 28  99  0 29  1 28     0
MatZeroEntries         1 1.0 9.3739e-02 5.9 0.00e+00 0.0 0.0e+00
0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet                 4 1.0 3.9721e-04 2.2 0.00e+00 0.0 0.0e+00
Memory usage is given in bytes:
Object Type          Creations   Destructions   Memory  Descendants' Mem.
              Matrix     3              0          0     0
           Index Set     6              6      45500     0
                 Vec     6              1     196776     0
         Vec Scatter     3              0          0     0
   IS L to G Mapping     2              0          0     0
       Krylov Solver     1              0          0     0
      Preconditioner     1              0          0     0
Average time to get PetscTime(): 1.71661e-06
Average time for MPI_Barrier(): 0.000159979
Average time for zero size MPI_Send(): 1.29938e-05
Compiled without FORTRAN kernels
Compiled with full precision matrices (default)
sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8
sizeof(PetscScalar) 8
Configure run at: Fri Sep 28 23:34:20 2007
run2
Time (sec):           2.298e+02      1.00000   2.298e+02
Objects:              2.600e+02      1.00000   2.600e+02
Flops:                1.265e+09      1.17394   1.161e+09  6.969e+09
Flops/sec:            5.505e+06      1.17394   5.054e+06  3.032e+07
MPI Messages:         1.436e+03      1.20816   1.326e+03  7.956e+03
MPI Message Lengths:  2.120e+07      1.23141   1.457e+04  1.159e+08
MPI Reductions:       4.192e+02      1.00000
N --> 2N flops
 0:      Main Stage: 2.2943e+02  99.8%  6.9689e+09 100.0%  7.944e+03
99.8%  1.457e+04      100.0%  2.230e+02   8.9%
Phase summary info:
      #                          WARNING!!!                    #
      #   meaningless.                                         #
MatMult              135 1.0 2.0830e+00 1.4 2.30e+08 1.9 2.4e+03
1.3e+04 0.0e+00  1 26 30 26  0   1 26 30 26  0   862
MatMultAdd            40 1.0 3.2598e-01 4.5 2.68e+07 5.7 0.0e+00
0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0    31
MatSolve              44 1.0 6.7841e-01 1.7 1.93e+08 1.7 0.0e+00
0.0e+00 0.0e+00  0  7  0  0  0   0  7  0  0  0   672
MatRelax              80 1.0 4.2949e+00 1.6 8.77e+07 1.2 2.2e+03
1.3e+04 0.0e+00  1 23 28 26  0   1 23 28 26  0   374
MatLUFactorSym         1 1.0 7.6739e-02 1.1 0.00e+00 0.0 0.0e+00
0.0e+00 1.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatLUFactorNum         2 1.0 2.9370e+00 1.5 2.53e+08 1.5 0.0e+00
0.0e+00 0.0e+00  1 44  0  0  0   1 44  0  0  0  1037
MatILUFactorSym        1 1.0 6.7334e-01 1.0 0.00e+00 0.0 0.0e+00
MatAssemblyBegin       7 1.0 7.1652e-01 4.4 0.00e+00 0.0 1.3e+02
2.9e+05 8.0e+00  0  0  2 32  0   0  0  2 32  4     0
MatAssemblyEnd         7 1.0 2.1473e+02 1.0 0.00e+00 0.0 8.4e+01
3.2e+03 2.2e+01 93  0  1  0  1  94  0  1  0 10     0
MatGetRowIJ            2 1.0 1.8899e-03 1.1 0.00e+00 0.0 0.0e+00
MatGetSubMatrice       1 1.0 3.1915e-02 1.0 0.00e+00 0.0 0.0e+00
0.0e+00 3.0e+00  0  0  0  0  0   0  0  0  0  1     0
MatGetOrdering         2 1.0 1.2184e-02 1.6 0.00e+00 0.0 0.0e+00
0.0e+00 4.0e+00  0  0  0  0  0   0  0  0  0  2     0
MatIncreaseOvrlp       1 1.0 7.6865e-02 1.0 0.00e+00 0.0 1.1e+03
2.4e+03 2.0e+01  0  0 13  2  1   0  0 13  2  9     0
MatZeroEntries         3 1.0 1.0429e-01 4.7 0.00e+00 0.0 0.0e+00
MAT_GetRedundantMatrix       1 1.0 3.0144e-02 1.2 0.00e+00 0.0 9.0e+01
8.0e+04 2.0e+00  0  0  1  6  0   0  0  1  6  1     0
VecDot                39 1.0 9.0680e-01140.0 2.95e+08191.3 0.0e+00
0.0e+00 3.9e+01  0  0  0  0  2   0  0  0  0 17    11
VecMDot                8 1.0 2.8777e-03 2.8 4.16e+07 3.3 0.0e+00
0.0e+00 8.0e+00  0  0  0  0  0   0  0  0  0  4    84
VecNorm               31 1.0 6.2301e-02 4.2 7.17e+07 5.8 0.0e+00
0.0e+00 3.1e+01  0  0  0  0  1   0  0  0  0 14    86
VecScale              85 1.0 1.7729e-03 1.4 4.94e+08 1.4 0.0e+00
0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  2138
VecCopy                4 1.0 6.2108e-04 1.5 0.00e+00 0.0 0.0e+00
VecSet               139 1.0 3.5934e-03 1.4 0.00e+00 0.0 0.0e+00
VecAXPY               98 1.0 5.1496e-03 1.3 9.24e+08 1.1 0.0e+00
0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  4705
VecAYPX               40 1.0 1.0311e-02 1.4 1.90e+08 1.0 0.0e+00
0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   969
VecWAXPY              75 1.0 2.6060e-02 1.4 1.22e+08 1.0 0.0e+00
0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   618
VecMAXPY               9 1.0 2.1315e-04 1.6 3.01e+08 1.2 0.0e+00
0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  1355
VecAssemblyBegin       4 1.0 1.9898e-03 1.2 0.00e+00 0.0 0.0e+00
0.0e+00 1.2e+01  0  0  0  0  0   0  0  0  0  5     0
VecAssemblyEnd         4 1.0 2.1219e-05 1.2 0.00e+00 0.0 0.0e+00
VecScatterBegin      267 1.0 1.0224e-01 1.6 0.00e+00 0.0 6.3e+03
1.1e+04 0.0e+00  0  0 79 59  0   0  0 79 59  0     0
VecScatterEnd        267 1.0 7.8653e-0111.3 0.00e+00 0.0 0.0e+00
KSPGMRESOrthog         4 1.0 3.7677e-03 1.9 4.78e+07 2.4 0.0e+00
0.0e+00 1.2e+01  0  0  0  0  0   0  0  0  0  5   141
KSPSetup               6 1.0 1.0260e-02 1.0 0.00e+00 0.0 0.0e+00
KSPSolve               2 1.0 7.8238e+00 1.0 1.16e+08 1.2 5.9e+03
1.1e+04 8.1e+01  3 70 75 54  3   3 70 75 54 36   622
PCSetUp                3 1.0 5.1323e+00 1.2 1.29e+08 1.2 1.6e+03
9.1e+03 7.3e+01  2 47 20 13  3   2 47 20 13 33   636
PCSetUpOnBlocks        1 1.0 1.3325e+00 1.0 1.47e+08 1.0 0.0e+00
0.0e+00 3.0e+00  1 17  0  0  0   1 17  0  0  1   871
PCApply               44 1.0 5.7917e+00 1.1 9.60e+07 1.2 4.7e+03
1.0e+04 0.0e+00  2 41 59 42  0   2 41 59 42  0   497
              Matrix    16              0          0     0
           Index Set    36             29     256760     0
                 Vec   176             93   16582464     0
         Vec Scatter    10              0          0     0
   IS L to G Mapping     4              0          0     0
       Krylov Solver     6              0          0     0
      Preconditioner     6              0          0     0
              Viewer     4              2          0     0
           Container     2              0          0     0
Average time to get PetscTime(): 8.10623e-07
Average time for MPI_Barrier(): 0.000178194
Average time for zero size MPI_Send(): 1.33117e-05
OptionTable: -mg_levels_ksp_type richardson
OptionTable: -mg_levels_pc_sor_omega 1.05
OptionTable: -mg_levels_pc_type sor
OptionTable: -pc_ml_PrintLevel 4
OptionTable: -pc_ml_maxNlevels 2
OptionTable: -pc_type ml
>     Barry
>     The a
> On Feb 3, 2008, at 6:44 AM, Thomas Geenen wrote:
> > i call
> > ierr = MatStashSetInitialSize(A[*seqsolve],stash_size,
> > stash_size);CHKERRQ(ierr);
> > with 100 000 000 for the stash size to make sure that's not the
> > bottleneck
> > the assemble time remains unchanged however.
> > nstash in MatAssemblyBegin_MPIAIJ (CPU=0) = 109485
> > reallocs in MatAssemblyBegin_MPIAIJ =  0
> > cheers
> > Thomas
> > On Saturday 02 February 2008 23:19, Barry Smith wrote:
> >>    The matstash has a concept of preallocation also. During the first
> >> setvalues
> >> it is allocating more and more memory for the stash. In the second
> >> setvalues
> >> the stash is large enough so does not require any addition
> >> allocation.
> >>    You can use the option -matstash_initial_size <size> to allocate
> >> enough space
> >> initially so that the first setvalues is also fast. It does not look
> >> like there is a way
> >> coded to get the <size> that you should use. It should be set to the
> >> maximum nonzeros
> >> any process has that belongs to other processes. The stash handling
> >> code is
> >> in src/mat/utils/matstash.c, perhaps you can figure out how to
> >> printout with PetscInfo()
> >> the sizes needed?
> >>    Barry
> >> On Feb 2, 2008, at 12:30 PM, Thomas Geenen wrote:
> >>> On Saturday 02 February 2008 18:33, Hong Zhang wrote:
> >>>> On Sat, 2 Feb 2008, Thomas Geenen wrote:
> >>>>> Dear Petsc users,
> >>>>> I would like to understand what is slowing down the assembly phase
> >>>>> of my
> >>>>> matrix. I create a matrix with MatCreateMPIAIJ i make a rough
> >>>>> guess of
> >>>>> the number of off diagonal entries and then use a conservative
> >>>>> value to
> >>>>> make sure I do not need extra mallocs. (the number of diagonal
> >>>>> entries is
> >>>>> exact)
> >>>>> next i call MatSetValues and MatAssemblyBegin, MatAssemblyEnd.
> >>>>> The first time i call MatSetValues and MatAssemblyBegin,
> >>>>> MatAssemblyEnd it takes about 170 seconds
> >>>>> the second time 0.3 seconds.
> >>>>> I run it on 6 cpu's and I do fill quit a number of row-entries on
> >>>>> the
> >>>>> "wrong" cpu. However thats also the case the second run. I checked
> >>>>> that there are no additional mallocs
> >>>>> MatGetInfo info.mallocs=0 both after MatSetValues and after
> >>>> Run your code with the option '-log_summary' and check which
> >>>> function
> >>>> call dominates the execution time.
> >>> the time is spend in MatStashScatterGetMesg_Private
> >>>>> the
> >>>>> "wrong" cpu.
> >>>> Likely, the communication that sending the entries to the
> >>>> corrected cpu consume the time. Can you fill the entries in the
> >>>> correct cpu?
> >>> the second time the entries are filled on the wrong CPU as well.
> >>> i am curious about the difference in time between run 1 and 2.
> >>>> Hong
> >>>>> cheers
> >>>>> Thomas
