PETSc + HYPRE
Márcio Ricardo Pivello pivello at gmail.com
Wed Apr 16 06:51:05 CDT 2008
Hi, Lisandro. I must apologize for not answering. I read your email and
changed my code, but then I went through a different path. I'm trying to
call the preconditioner from the command line, without any mention to it in
the source code. It should take a couple of hours to get some results and
then, if it doesn't work, I'll change the code.
Thank you very much.
Márcio Ricardo
On Tue, Apr 15, 2008 at 8:43 PM, Lisandro Dalcin <dalcinl at gmail.com> wrote:
> Sorry for my insistence, but... Did you see my previous mail? The code
> you wrote is not OK. You have to first create the KSP, next extract
> the PC with KSPGetPC, and then configure the PC to use HYPRE+BoomerAMG
> To be sure you are actually being using hypre, add -ksp_view to command
> line.
> On 4/15/08, Márcio Ricardo Pivello <pivello at gmail.com> wrote:
> > Hy, Matthew, thanks for your help.
> > Firstly, I'm solving a 3D Incompressible Navier Stokes solver based on
> FEM,
> > with fluid-structure interaction. In this case, I'm simulating the blood
> > flow inside an aneurysm in an abdominal aorta artery.
> >  By not working I mean the error does not decrease with time. Our team
> is
> > just starting using HYPRE, in fact this is the very first case we run
> with
> > it.
> > Again, thanks for your help.
> > Márcio Ricardo.
> Lisandro Dalcín
> Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
> Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
> Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
> PTLC - Güemes 3450, (3000) Santa Fe, Argentina
> Tel/Fax: +54-(0)342-451.1594
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20080416/d5b88e31/attachment.htm>
