PETSc + HYPRE
Lisandro Dalcin dalcinl at gmail.com
Tue Apr 15 18:43:22 CDT 2008
Sorry for my insistence, but... Did you see my previous mail? The code
you wrote is not OK. You have to first create the KSP, next extract
the PC with KSPGetPC, and then configure the PC to use HYPRE+BoomerAMG
To be sure you are actually being using hypre, add -ksp_view to command line.
On 4/15/08, Márcio Ricardo Pivello <pivello at gmail.com> wrote:
> Hy, Matthew, thanks for your help.
> Firstly, I'm solving a 3D Incompressible Navier Stokes solver based on FEM,
> with fluid-structure interaction. In this case, I'm simulating the blood
> flow inside an aneurysm in an abdominal aorta artery.
>  By not working I mean the error does not decrease with time. Our team is
> just starting using HYPRE, in fact this is the very first case we run with
> it.
> Again, thanks for your help.
> Márcio Ricardo.
Lisandro Dalcín
Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
PTLC - Güemes 3450, (3000) Santa Fe, Argentina
Tel/Fax: +54-(0)342-451.1594
