Slow speed after changing from serial to parallel
Ben Tay zonexo at gmail.com
Mon Apr 14 08:43:36 CDT 2008
Hi Matthew,
I think you've misunderstood what I meant. What I'm trying to say is
initially I've got a serial code. I tried to convert to a parallel one.
Then I tested it and it was pretty slow. Due to some work requirement, I
need to go back to make some changes to my code. Since the parallel is
not working well, I updated and changed the serial one.
Well, that was a while ago and now, due to the updates and changes, the
serial code is different from the old converted parallel code. Some
files were also deleted and I can't seem to get it working now. So I
thought I might as well convert the new serial code to parallel. But I'm
not very sure what I should do 1st.
Maybe I should rephrase my question in that if I just convert my poisson
equation subroutine from a serial PETSc to a parallel PETSc version,
will it work? Should I expect a speedup? The rest of my code is still
serial.
Thank you very much.
Matthew Knepley wrote:
> I am not sure why you would ever have two codes. I never do this. PETSc
> is designed to write one code to run in serial and parallel. The PETSc part
> should look identical. To test, run the code yo uhave verified in serial and
> output PETSc data structures (like Mat and Vec) using a binary viewer.
> Then run in parallel with the same code, which will output the same
> structures. Take the two files and write a small verification code that
> loads both versions and calls MatEqual and VecEqual.
>   Matt
> On Mon, Apr 14, 2008 at 5:49 AM, Ben Tay <zonexo at gmail.com> wrote:
>> Thank you Matthew. Sorry to trouble you again.
>>  I tried to run it with -log_summary output and I found that there's some
>> errors in the execution. Well, I was busy with other things and I just came
>> back to this problem. Some of my files on the server has also been deleted.
>> It has been a while and I  remember that  it worked before, only much
>> slower.
>>  Anyway, most of the serial code has been updated and maybe it's easier to
>> convert the new serial code instead of debugging on the old parallel code
>> now. I believe I can still reuse part of the old parallel code. However, I
>> hope I can approach it better this time.
>>  So supposed I need to start converting my new serial code to parallel.
>> There's 2 eqns to be solved using PETSc, the momentum and poisson. I also
>> need to parallelize other parts of my code. I wonder which route is the
>> best:
>>  1. Don't change the PETSc part ie continue using PETSC_COMM_SELF, modify
>> other parts of my code to parallel e.g. looping, updating of values etc.
>> Once the execution is fine and speedup is reasonable, then modify the PETSc
>> part - poisson eqn 1st followed by the momentum eqn.
>>  2. Reverse the above order ie modify the PETSc part - poisson eqn 1st
>> followed by the momentum eqn. Then do other parts of my code.
>>  I'm not sure if the above 2 mtds can work or if there will be conflicts. Of
>> course, an alternative will be:
>>  3. Do the poisson, momentum eqns and other parts of the code separately.
>> That is, code a standalone parallel poisson eqn and use samples values to
>> test it. Same for the momentum and other parts of the code. When each of
>> them is working, combine them to form the full parallel code. However, this
>> will be much more troublesome.
>>  I hope someone can give me some recommendations.
>>  Thank you once again.
>>> 1) There is no way to have any idea what is going on in your code
>>>    without -log_summary output
>>> 2) Looking at that output, look at the percentage taken by the solver
>>>    KSPSolve event. I suspect it is not the biggest component, because
>>>   it is very scalable.
>>>   Matt
>>> On Sun, Apr 13, 2008 at 4:12 AM, Ben Tay <zonexo at gmail.com> wrote:
>>>> Hi,
>>>> I've a serial 2D CFD code. As my grid size requirement increases, the
>>>> simulation takes longer. Also, memory requirement becomes a problem.
>> Grid
>>>> size 've reached 1200x1200. Going higher is not possible due to memory
>>>> problem.
>>>> I tried to convert my code to a parallel one, following the examples
>> given.
>>>> I also need to restructure parts of my code to enable parallel looping.
>> I
>>>> 1st changed the PETSc solver to be parallel enabled and then I
>> restructured
>>>> parts of my code. I proceed on as longer as the answer for a simple test
>>>> case is correct. I thought it's not really possible to do any speed
>> testing
>>>> since the code is not fully parallelized yet. When I finished during
>> most of
>>>> the conversion, I found that in the actual run that it is much slower,
>>>> although the answer is correct.
>>>> So what is the remedy now? I wonder what I should do to check what's
>> wrong.
>>>> Must I restart everything again? Btw, my grid size is 1200x1200. I
>> believed
>>>> it should be suitable for parallel run of 4 processors? Is that so?
>>>> Thank you.
