Slow speed after changing from serial to parallel
Mon Apr 14 08:23:48 CDT 2008
I am not sure why you would ever have two codes. I never do this. PETSc
is designed to write one code to run in serial and parallel. The PETSc part
should look identical. To test, run the code yo uhave verified in serial and
output PETSc data structures (like Mat and Vec) using a binary viewer.
Then run in parallel with the same code, which will output the same
structures. Take the two files and write a small verification code that
loads both versions and calls MatEqual and VecEqual.
  Matt
On Mon, Apr 14, 2008 at 5:49 AM, Ben Tay <zonexo at gmail.com> wrote:
> Thank you Matthew. Sorry to trouble you again.
>  I tried to run it with -log_summary output and I found that there's some
> errors in the execution. Well, I was busy with other things and I just came
> back to this problem. Some of my files on the server has also been deleted.
> It has been a while and I  remember that  it worked before, only much
> slower.
>  Anyway, most of the serial code has been updated and maybe it's easier to
> convert the new serial code instead of debugging on the old parallel code
> now. I believe I can still reuse part of the old parallel code. However, I
> hope I can approach it better this time.
>  So supposed I need to start converting my new serial code to parallel.
> There's 2 eqns to be solved using PETSc, the momentum and poisson. I also
> need to parallelize other parts of my code. I wonder which route is the
> best:
>  1. Don't change the PETSc part ie continue using PETSC_COMM_SELF, modify
> other parts of my code to parallel e.g. looping, updating of values etc.
> Once the execution is fine and speedup is reasonable, then modify the PETSc
> part - poisson eqn 1st followed by the momentum eqn.
>  2. Reverse the above order ie modify the PETSc part - poisson eqn 1st
> followed by the momentum eqn. Then do other parts of my code.
>  I'm not sure if the above 2 mtds can work or if there will be conflicts. Of
> course, an alternative will be:
>  3. Do the poisson, momentum eqns and other parts of the code separately.
> That is, code a standalone parallel poisson eqn and use samples values to
> test it. Same for the momentum and other parts of the code. When each of
> them is working, combine them to form the full parallel code. However, this
> will be much more troublesome.
>  I hope someone can give me some recommendations.
>  Thank you once again.
>  Matthew Knepley wrote:
> > 1) There is no way to have any idea what is going on in your code
> >    without -log_summary output
> > 2) Looking at that output, look at the percentage taken by the solver
> >    KSPSolve event. I suspect it is not the biggest component, because
> >   it is very scalable.
> >   Matt
> > On Sun, Apr 13, 2008 at 4:12 AM, Ben Tay <zonexo at gmail.com> wrote:
> > > Hi,
> > > I've a serial 2D CFD code. As my grid size requirement increases, the
> > > simulation takes longer. Also, memory requirement becomes a problem.
> Grid
> > > size 've reached 1200x1200. Going higher is not possible due to memory
> > > problem.
> > > I tried to convert my code to a parallel one, following the examples
> given.
> > > I also need to restructure parts of my code to enable parallel looping.
> I
> > > 1st changed the PETSc solver to be parallel enabled and then I
> restructured
> > > parts of my code. I proceed on as longer as the answer for a simple test
> > > case is correct. I thought it's not really possible to do any speed
> testing
> > > since the code is not fully parallelized yet. When I finished during
> most of
> > > the conversion, I found that in the actual run that it is much slower,
> > > although the answer is correct.
> > > So what is the remedy now? I wonder what I should do to check what's
> wrong.
> > > Must I restart everything again? Btw, my grid size is 1200x1200. I
> believed
> > > it should be suitable for parallel run of 4 processors? Is that so?
> > > Thank you.
experiments is infinitely more interesting than any results to which
their experiments lead.
-- Norbert Wiener
