Question on DA
Fri Apr 11 08:24:36 CDT 2008
    The default layouts of "grid points" is independent of the number
of degree's
of freedom per point so each process will get the same "patch" for
both DA's.
   If you are worried about the two DA's having some duplicate
information that
wastes memory (information that could be shared between the two),
don't; the
amount of excess data is very small relative to everything else in the
code and
is not worth worrying about.
    Barry
On Apr 10, 2008, at 11:28 PM, Ningyu Liu wrote:
> Hello,
> I have a question on DA. If I create two DAs using DACreate2D() with
> the
> same input except different degrees of freedom, will they share the
> same
> communication information. If not, how can I create two DAs
> corresponding
> to the same structured grid and communication information but
> different
> degrees of freedom. Thank you very much!
> Ningyu
