DA question
Sean Dettrick sdettrick at gmail.com
Wed Apr 9 16:36:05 CDT 2008
To elaborate on Matt's suggestion, a staggered grid/Yee mesh code
could use a single DA with one degree-of-freedom per component of H
and E.  The extra overlap required for staggered guard cells at the
domain boundaries could be dealt with by having a bigger-than-usual
stencil width.  For the 2nd order 3D case, this suggests the
DACreate3d routine would have arguments dof=6, s=2, and
stencil_type=DA_STENCIL_STAR.
It is just a suggestion - I have not tried it.
Sean
On Wed, Apr 9, 2008 at 5:06 PM,  <Amit.Itagi at seagate.com> wrote:
> Randy,
>  I guess, since you are doing a frequency domain calculation, you eventually
>  end up with a single matrix equation.
>  I am planning to work in the time domain. Will that change things ?
>  Thanks
>  Rgds,
>  Amit
>              Randall Mackie
>              <rlmackie862 at gmai
>              l.com>                                                     To
>              Sent by:                  petsc-users at mcs.anl.gov
>              owner-petsc-users                                          cc
>              @mcs.anl.gov
>              No Phone Info                                         Subject
>              Available                 Re: DA question
>              04/09/2008 04:09
>              PM
>              Please respond to
>                   nl.gov
>  Hi Amit,
>  Why do you need two staggered grids? I do EM finite difference frequency
>  domain modeling on a staggered grid using just one DA. Works perfectly
>  fine.
>  There are some grid points that are not used, but you just set them to zero
>  and put a 1 on the diagonal of the coefficient matrix.
>  Randy
>  Amit.Itagi at seagate.com wrote:
>  > Hi Berend,
>  > A detailed explanation of the finite difference scheme is given here :
>  > http://en.wikipedia.org/wiki/Finite-difference_time-domain_method
>  > Thanks
>  > Rgds,
>  > Amit
>  >              Berend van Wachem
>  >              <berend at chalmers.
>  >              se>
>  To
>  >              owner-petsc-users
>  cc
>  >              @mcs.anl.gov
>  >              No Phone Info
>  Subject
>  >              04/09/2008 02:59
>  >              PM
>  >              Please respond to
>  >                   nl.gov
>  > Dear Amit,
>  > Could you explain how the two grids are attached?
>  > I am using multiple DA's for multiple structured grids glued together.
>  > I've done the gluing with setting up various IS objects. From the
>  > multiple DA's, one global variable vector is formed. Is that what you
>  > are looking for?
>  > Best regards,
>  > Berend.
>  >> Hi,
>  >> Is it possible to use DA to perform finite differences on two staggered
>  >> regular grids (as in the electromagnetic finite difference time domain
>  >> method) ? Surrounding nodes from one grid are used to update the value
>  in
>  >> the dual grid. In addition, local manipulations need to be done on the
>  >> nodal values.
>  >> Thanks
>  >> Rgds,
>  >> Amit
