OpenMPI, PETSc and petsc4py in a Mac Intel
Ondrej Certik ondrej at certik.cz
Tue Sep 11 09:20:24 CDT 2007
thanks for your instructions. For those using Debian, that want to
have exactly the same configuration (petsc2.3.3 with superlu and
umfpack, openmpi, petsc4py), just add unstable into your sources.list
and do
apt-get install python-petsc4py
and that's it.
Ondrej
On 9/10/07, Matthew Knepley <knepley at gmail.com> wrote:
> Thanks for your thorough directions. I have incorporated them into the
> installation page
> for dev, which will become public on the upcoming release.
>   Matt
> On 9/10/07, Felipe Cruz <refac at bristol.ac.uk> wrote:
> > Hi all,
> > During the past weeks I was trying to install the Python bindings for
> > PETSc (petsc4py) for
> > Mac Intel (a black Macbook and an Aluminium iMac, both with OS X
> > 10.4.10)
> > I succeeded and "how I did it"  might be helpful for some others
> > Python-PETSc-Mac-Users.
> > Before to start the installation you'll need to have installed:
> > * XcodeTools:
> > It is IMPORTANT to get the latest version directly from Apple's
> > website (http://connect.apple.com), the version
> > that comes with the installation CD have some issues (or not so nice
> > "features".) I recommend to upgrade
> > your XcodeTools before trying to install anything.
> > * Python 2.5, Numpy, Scipy (optional - scientific lib) and Matplotlib
> > (optional -matlab style graphics):
> > I followed the installation of this packages from: http://
> > www.scipy.org/Download
> > I installed MacPython2.5 and the SuperPack. For some reason
> > Matplotlib didn't work after the installation
> > of the superpack, so I manually installed it again from: http://
> > matplotlib.sourceforge.net/
> > INSTALLATION
> > I'll describe the whole installation of OpenMPI, PETSc and petsc4py.
> > OpenMpi
> > Download OpenMPI source from:
> > http://www.open-mpi.org/software/ompi/v1.2/
> > Decompress the downloaded tar.gz file and from a terminal "cd" into
> > the openMpi folder.
> > '$' indicates a terminal command, e.g;
> > $ tar -xzvf openmpi-1.2.3.tar.gz
> > $ cd openmpi-1.2.3
> > Now you can compile openmpi
> > $ ./configure --prefix=/usr/local/openmpi --with-fortran --enable-
> > shared --disable-static --with-xgrid
> > $ sudo make
> > $ sudo make install
> > Add the next line at the END of /etc/profile, so the path will be
> > available for all the users:
> > export PATH=$PATH:/usr/local/openmpi/bin
> > PETSc
> > First you need to make sure that OpenMPI is properly installed! check
> > that
> > mpicc and mpif77 are in your $PATH before running the PETSc
> > configure.py!
> > (if you added the export PATH to /etc/profile you can close your
> > terminal and
> > open a new terminal, the PATH should be working now, otherwise, you
> > can just type
> > in your terminal:
> > I installed PETSc on /opt/petsc
> > $ sudo mkdir /opt
> > $ sudo mkdir /opt/petsc
> > Set permissions for user and group.
> > $ sudo chown user:group /opt/petsc
> > In my case I added the user 'felipe' and the group 'admin' (sudo
> > chown felipe:admin /opt/petsc)
> > Download PETSc from:
> > http://www-unix.mcs.anl.gov/petsc/petsc-as/download/index.html
> > Save the downloaded tar.gz on /opt/petsc
> > Decompress the file
> > $ cd /opt/petsc
> > $ tar -xzvf petsc-2.3.3-p5.tar.gz
> > I installed petscy for shared libraries and without X, beside this
> > everything is normal:
> > $ cd petsc-2.3.3-p5
> > $ export PETSC_ARCH=darwin8.10.1-c-debug
> > $ export PETSC_DIR=/opt/petsc/petsc-2.3.3-p5
> > $ ./config/configure.py --with-mpi-dir=/usr/local/openmpi --with-
> > shared=1 --with-x=0
> > $ make all test
> > At the end of /etc/profile add (so it will be available for all the
> > users):
> > # variables for petsc
> > petsc4py
> > Open a new terminal so the variables PETSC_ARCH and PETSC_DIR will be
> > available.
> > I installed petsc4py in /opt/petsc/petsc4py
> > In a terminal
> > $ cd /opt/petsc/petsc4py
> > Get a copy of petsc4py from: http://code.google.com/p/petsc4py/
> > and save it at /opt/petsc/petsc4py
> > $ tar -xvf petsc4py-0.7.5.tar
> > $ cd petsc4py-0.7.5
> > $ python setup.py install --home=/opt/petsc/petsc4py
> > # Add at the end of /etc/profile (it will be available for all the
> > users)
> > export PYTHONPATH=/opt/petsc/petsc4py/lib/python/
> > Now is possible to open a new terminal and test petsc4py:
> > $python
> >  >>> from petsc4py import PETSc
> >  >>> A = PETSc.Mat()
> >  >>> A
> >  >>> A.createSeqAIJ(1000)
> > Hope that this info is helpful! I tested the installation in my
> > MacBook (Dual-core), in an aluminium iMac (Dual-core),
> > and I hope to test the installation on a Mac pro (with two quad-core)
> > some time this week!
> > I'm quite new to the list so I'm sorry if you have already discussed
> > this topic.
> > Best regards,
> > Felipe Cruz
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
