[PETSC #16696] Binary dump of SNES residuals
mspieg mspieg at ldeo.columbia.edu
Mon Sep 10 16:42:08 CDT 2007
Thanks Barry,
      I hacked up something using SNESMonitorSet and a binary viewer
that works (although not quite 1-3 lines of code).  This will work
great...thanks...
cheers
marc
On Sep 10, 2007, at 4:38 PM, Barry Smith wrote:
>> I can certainly use  SNESMonitorSet with a custom monitor that
>> sets up a
>> binary viewer for SNESMonitorResidual, but I'm being lazy.
>   This is currently the way to go: should require 3 lines of code,
> create the binary
> viewer, call SNESMonitorSet() and then destroy the viewer at the
> end. You
> can make it one line of code by passing PETSC_BINARY_VIEWER_WORLD
> into the
> the SNESMonitorSet() call.
>   It would be nice to have a very generally solution to this, so
> one could
> easily direct to many different types of viewers from the options
> database.
> Maybe a rework of VecView_Private() code being used in conjunction
> with the
> various -xxx_monitor_residual/solution/update options, for KSP,
> SNES and TS.
> Do I have time to write it? Heck no, I don't even have time to read
> my email :-)
>    Barry
> On Mon, 10 Sep 2007, mspieg wrote:
>> Apologies if this is obvious,  but is there a clean way to dump
>> out SNES
>> residuals (and or updates) (inside a DMMG) as binary vectors for
>> debugging.
>> I'm currently using
>> -snes_monitor_residual
>> which is lovely for visualizing the residuals but uses VecView
>> with the
>> default Viewer set to draw and it would be useful to have a
>> command line
>> option to change the viewer type to binary (if it doesn't already
>> exist)
>> sets up a
>> Any and all help greatly appreciated.
>> cheers
>> marc
>> Marc Spiegelman
>> Lamont-Doherty Earth Observatory
>> Dept. of Applied Physics/Applied Math
>> Columbia University
>> http://www.ldeo.columbia.edu/~mspieg
Marc Spiegelman
Columbia University
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20070910/0f41f70e/attachment.htm>
