PCFactorSetLevels does not work?!
Wed Oct 31 12:28:26 CDT 2007
   Are you calling the PCFactorSetLevels() on the prec where the
ICC is being used. For example if your * below means
-sub_pc_factor_levels then you need to use
PCBJacobiGetSubKSP() then get the PC out of that that subksp
and call the PCFactorSetLevels() on that
  Barry
On Wed, 31 Oct 2007, Zhifeng Sheng wrote:
> Dear all
> I have a weird problem.
> In my programme, I try to use ICC(K), while I set the factor level with
> PCFactorSetLevels(prec, 4);
> However this does not work.
> Then I run the executable with the option *-pc_factor_levels 4, it works...
> Can someone tell me why this is happenning?
> Thank you
> Best regards
> Zhifeng Sheng
