PCFactorSetLevels does not work?!
Lisandro Dalcin dalcinl at gmail.com
Wed Oct 31 12:25:32 CDT 2007
Did you call PCSetType(prec,PCICC) or PCSetFromOptions(prec) before
calling PCFactorSetLevels(prec, 4) ?? If not, that call would be
ignored.
On 10/31/07, Zhifeng Sheng <z.sheng at ewi.tudelft.nl> wrote:
> Dear all
> I have a weird problem.
> In my programme, I try to use ICC(K), while I set the factor level with
> PCFactorSetLevels(prec, 4);
> However this does not work.
> Then I run the executable with the option *-pc_factor_levels 4, it works...
> Can someone tell me why this is happenning?
> Thank you
> Best regards
> Zhifeng Sheng
Lisandro Dalcín
Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
PTLC - Güemes 3450, (3000) Santa Fe, Argentina
Tel/Fax: +54-(0)342-451.1594
