Invalid argument! - not a permutation!
Thu Oct 25 14:26:12 CDT 2007
On 10/25/07, Tim Stitt <timothy.stitt at ichec.ie> wrote:
> OK...that is useful thanks.
> If you don't mind just one more question...I notice that the
> MatLUFactorSymbolic() routine now executes with one processor but
> complains when I run > 2 processors. The actual error message is:
> [1]PETSC ERROR: No support for this operation for this object type!
> [1]PETSC ERROR: Matrix type mpiaij  symbolic LU!
> Is this because the default LU factorisation routine isn't parallel...I
> just assumed parallel superlu would be picked up automatically (it is
> compiled into my PETSc build) ?
It is only valid for the superlu matrix type, -mat_type superlu_dist.
  Matt
> Tim.
> Barry Smith wrote:
> >   I have added this information to the error message that gets printed.
> >    Barry
> > On Thu, 25 Oct 2007, Matthew Knepley wrote:
> >> I think you need to tell use that the IS is a permutation:
> >> http://www-unix.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-current/docs/manualpages/IS/ISSetPermutation.html
> >>    Matt
> >>> Hi all,
> >>> Following on from some help I got a few days ago with respect to
> >>> MatLUFactorSymbolic() usage in Fortran...I think I now have all the
> >>> parts in place but keep getting the following runtime error upon execution:
> >>> [0]PETSC ERROR: --------------------- Error Message
> >>> [0]PETSC ERROR: Invalid argument!
> >>> [0]PETSC ERROR: not a permutation!
> >>> [0]PETSC ERROR:
> >>> [0]PETSC ERROR: ISInvertPermutation() line 183 in
> >>> src/vec/is/interface/index.c
> >>> [0]PETSC ERROR: MatLUFactorSymbolic_SeqAIJ() line 276 in
> >>> src/mat/impls/aij/seq/aijfact.c
> >>> [0]PETSC ERROR: MatLUFactorSymbolic() line 2178 in
> >>> src/mat/interface/matrix.c
> >>> [localhost.localdomain:24730] MPI_ABORT invoked on rank 0 in
> >>> communicator MPI_COMM_WORLD with errorcode 62
> >>> Here is the portion of  the offending code (I think):
> >>>   call MatAssemblyBegin(A,MAT_FINAL_ASSEMBLY,error);CHKERRQ(error)
> >>>   call MatAssemblyEnd(A,MAT_FINAL_ASSEMBLY,error);CHKERRQ(error)
> >>>   call ISCreateGeneral(PETSC_COMM_WORLD,order,columnIndices,
> >>> indexSet,error);CHKERRQ(error)
> >>>   call MatFactorInfoInitialize(info,error);CHKERRQ(error)
> >>>   call
> >>> MatLUFactorSymbolic(A,indexSet,indexSet,info,factorMat,error);CHKERRQ(error)
> >>> order - number of rows/columns in square matrix A
> >>> columnIndices - 1D array containing values 0-->order-1
> >>> All types are set correctly as far as I can tell.
> >>> Can anyone suggest why the execution falls over during the
> >>> MatLUFactorSymbolic() call?
> >>> Thanks again,
> >>> Tim.
> >>> Dr. Timothy Stitt <timothy_dot_stitt_at_ichec.ie>
> >>> HPC Application Consultant - ICHEC (www.ichec.ie)
> >>> Dublin Institute for Advanced Studies
> >>> 5 Merrion Square - Dublin 2 - Ireland
> >>> +353-1-6621333 (tel) / +353-1-6621477 (fax)
experiments is infinitely more interesting than any results to which
their experiments lead.
-- Norbert Wiener
