Invalid argument! - not a permutation!
Tim Stitt timothy.stitt at ichec.ie
Thu Oct 25 14:22:58 CDT 2007
OK...that is useful thanks.
If you don't mind just one more question...I notice that the
MatLUFactorSymbolic() routine now executes with one processor but
complains when I run > 2 processors. The actual error message is:
[1]PETSC ERROR: No support for this operation for this object type!
[1]PETSC ERROR: Matrix type mpiaij  symbolic LU!
Is this because the default LU factorisation routine isn't parallel...I
just assumed parallel superlu would be picked up automatically (it is
compiled into my PETSc build) ?
Tim.
Barry Smith wrote:
>   I have added this information to the error message that gets printed.
>    Barry
> On Thu, 25 Oct 2007, Matthew Knepley wrote:
>> I think you need to tell use that the IS is a permutation:
>> http://www-unix.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-current/docs/manualpages/IS/ISSetPermutation.html
>>    Matt
>> On 10/25/07, Tim Stitt <timothy.stitt at ichec.ie> wrote:
>>> Hi all,
>>> Following on from some help I got a few days ago with respect to
>>> MatLUFactorSymbolic() usage in Fortran...I think I now have all the
>>> parts in place but keep getting the following runtime error upon execution:
>>> [0]PETSC ERROR: --------------------- Error Message
>>> [0]PETSC ERROR: Invalid argument!
>>> [0]PETSC ERROR: not a permutation!
>>> [0]PETSC ERROR:
>>> [0]PETSC ERROR: ISInvertPermutation() line 183 in
>>> src/vec/is/interface/index.c
>>> [0]PETSC ERROR: MatLUFactorSymbolic_SeqAIJ() line 276 in
>>> src/mat/impls/aij/seq/aijfact.c
>>> [0]PETSC ERROR: MatLUFactorSymbolic() line 2178 in
>>> src/mat/interface/matrix.c
>>> [localhost.localdomain:24730] MPI_ABORT invoked on rank 0 in
>>> communicator MPI_COMM_WORLD with errorcode 62
>>> Here is the portion of  the offending code (I think):
>>>   call MatAssemblyBegin(A,MAT_FINAL_ASSEMBLY,error);CHKERRQ(error)
>>>   call MatAssemblyEnd(A,MAT_FINAL_ASSEMBLY,error);CHKERRQ(error)
>>>   call ISCreateGeneral(PETSC_COMM_WORLD,order,columnIndices,
>>> indexSet,error);CHKERRQ(error)
>>>   call MatFactorInfoInitialize(info,error);CHKERRQ(error)
>>>   call
>>> MatLUFactorSymbolic(A,indexSet,indexSet,info,factorMat,error);CHKERRQ(error)
>>> order - number of rows/columns in square matrix A
>>> columnIndices - 1D array containing values 0-->order-1
>>> All types are set correctly as far as I can tell.
>>> Can anyone suggest why the execution falls over during the
>>> MatLUFactorSymbolic() call?
>>> Thanks again,
>>> Tim.
>>> Dr. Timothy Stitt <timothy_dot_stitt_at_ichec.ie>
>>> HPC Application Consultant - ICHEC (www.ichec.ie)
>>> Dublin Institute for Advanced Studies
>>> 5 Merrion Square - Dublin 2 - Ireland
>>> +353-1-6621333 (tel) / +353-1-6621477 (fax)
