Validate a Object
Wed Oct 24 09:10:40 CDT 2007
Mat A=0;
if (A) MatDestroy(A);
Satish
On Wed, 24 Oct 2007, Zhifeng Sheng wrote:
> Dear all
> I am programming a simulator with PetSc, and I need to create matrix and
> vector which shall be destoried in the end.
> However, the problem is : sometimes, a matrix is declared but never created,
> and if I try to destory this object, Petsc would dump error.
> Is there anyway to check whether a Mat or Vec has been created or not?
> e.g
> Mat A;
> MatDestory A; // this will dump error, which function should I use to check
> whether A is created?
> Thank you.
> Best regards
> Zhifeng Sheng
