MatLUFactorSymbolic
Tim Stitt timothy.stitt at ichec.ie
Mon Oct 22 15:41:49 CDT 2007
Many thanks...that helps immensely.
Barry Smith wrote:
>   It should be
>    MatFactorInfo  info(MAT_FACTORINFO_SIZE)
>    The elements in the info array can found at
> http://www-unix.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-current/docs/manualpages/Mat/MatFactorInfo.html
> You can call MatFactorInfoInitialize() to set default values into the array and
> then change those you wish to (or change none).
>    Barry
> I have added this info to the MatFactorInfo manual page.
> On Mon, 22 Oct 2007, Tim Stitt wrote:
>> Hi all,
>> I am trying to call the routine MatLUFactorSymbolic in my Fortran PETSc code
>> and I am having some difficulties in figuring out what argument should be
>> passed to the
>> MatFactorInfo *info
>> parameter?
>> Can someone describe the possible values that this parameter can take within a
>> Fortran calling interface?
>> Thanks in advance,
>> Tim.
