MatLUFactorSymbolic
Mon Oct 22 15:25:15 CDT 2007
  It should be
   MatFactorInfo  info(MAT_FACTORINFO_SIZE)
   The elements in the info array can found at
http://www-unix.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-current/docs/manualpages/Mat/MatFactorInfo.html
You can call MatFactorInfoInitialize() to set default values into the array and
then change those you wish to (or change none).
   Barry
I have added this info to the MatFactorInfo manual page.
On Mon, 22 Oct 2007, Tim Stitt wrote:
> Hi all,
> I am trying to call the routine MatLUFactorSymbolic in my Fortran PETSc code
> and I am having some difficulties in figuring out what argument should be
> passed to the
> MatFactorInfo *info
> parameter?
> Can someone describe the possible values that this parameter can take within a
> Fortran calling interface?
> Thanks in advance,
> Tim.
