Compiled information for Petsc 2.3.2-p10
Lisandro Dalcin dalcinl at gmail.com
Tue Oct 9 14:30:37 CDT 2007
I want to suggest you to update to 2.3.3. Of course, you have the
extra trouble of figuring out yourself the cummulative changes since
2.2.1.
Go ahead updating to 2.3.3, and I can help you at any point you have trouble.
On 10/9/07, Trivedi, Jagruti CIV 470000D, 474300D
<jagruti.trivedi at navy.mil> wrote:
> Do you mean that I should apply changes from 2.2.1 to 2.3.0 and then
> 2.3.1 and so forth until I come upto 2.3.3 version or I can apply
> directly from 2.2.1 to 2.3.3?
> ...Jagruti
> -----Original Message-----
> From: owner-petsc-users at mcs.anl.gov
> [mailto:owner-petsc-users at mcs.anl.gov] On Behalf Of Satish Balay
> Sent: Tuesday, October 09, 2007 11:29
> To: petsc-users at mcs.anl.gov
> Subject: Re: Compiled information for Petsc 2.3.2-p10
> It is possible that we didn't document all the changes between releases.
> But the recommended approach is to look at changes file for each version
> after 2.2.1 - and apply these changes.
> And if your code is in C - then the compiler will help in finding any
> undocumented changes in prototypes.. etc..
> BTW: the current release version is 2.3.3 [so you might want to upgrade
> to this version instead of 2.3.2]
> Satish
> On Tue, 9 Oct 2007, Trivedi, Jagruti CIV 470000D, 474300D wrote:
> > Hello there,
> > I am trying to port my application from petsc 2.2.1 to petsc
> 2.3.2-p10.
> > Has anybody compiled
> > The real life changes needed to make other than listed in the changes
> > file?
> > I really appreciate if you have hands on do's and don'ts for porting
> > from petsc-2.2.1 to Petsc 2.3.2-p10.
> > Looking forward to positive replies.
> > Thanks and Best Regards,
> > ....Jagruti
> > NAWC
Lisandro Dalcín
Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
PTLC - Güemes 3450, (3000) Santa Fe, Argentina
Tel/Fax: +54-(0)342-451.1594
