Compiler Optimization Override
Berend van Wachem berend at chalmers.se
Thu Oct 4 11:02:44 CDT 2007
Hi Tim,
>> Ideally I would prefer a solution which doesn't involve rebuilding PETSc each
>> time I want to switch the optimization level. I tried to add the switch to
>> the petscrules file but it always defaulted to the first (lower?)
>> optimization switch that appeared in the application compile command line
>> which seems to be built into PETSc.
I do this by having a different PETSC_ARCH setting for each different
configuration. Then you only have to change this variable and rebuild
your application.
Berend.
