Compiler Optimization Override
Thu Oct 4 10:36:40 CDT 2007
  It seems the config/configure.py options -COPTFLAGS, -CXXOPTFLAGS, -FOPTFLAGS
work correctly. That is if you set them then the default optimization is turned
off and what you provide is used. This works with petsc-dev.
  If this does not work for someone please send configure.log so we can
resolve the problem.
   Barry
On Wed, 27 Jun 2007, Tim Stitt wrote:
> Hi PETSc Users/Developers,
> Could someone explain how I can override the default optimization level that
> comes with my PETSc build (currently -O). I want to set a more aggressive
> optimization level (e.g. -O3) for my compiler (PathScale).
> Ideally I would prefer a solution which doesn't involve rebuilding PETSc each
> time I want to switch the optimization level. I tried to add the switch to
> the petscrules file but it always defaulted to the first (lower?)
> optimization switch that appeared in the application compile command line
> which seems to be built into PETSc.
> Any help gratefully received.
> Regards,
> Tim.
