about mkl_p4p.dll not found
Sat May 26 10:59:43 CDT 2007
BTW: we have a new relaese petsc-2.3.3 - which you might want to use.
Satish
On Sat, 26 May 2007, Satish Balay wrote:
> MLK is installed in \petsc-2.3.2-p3\externalpackages? Sounds like a
> nonstandard install of MLK.
> Yes - on windows the location of all .dll files that are used should
> be set in PATH env variable. The MLK installer should probably do this
> automatically.
> Satish
> On Sat, 26 May 2007, Yixun Liu wrote:
> > Hi,
> > My program is based on PETSC. Its compiler and link is ok, but when execute a error was generated. The error is:
> > "MKL FATAL ERROR: Cannot load neither mkl_p4p.dll nor mkl_def.dllPress any key to continue"
> > I can find the mkl_p4p.dll in  "D:\MyVC\petsc-2.3.2-p3\externalpackages\w_mkl_serial_p_8.1.001\mkl_serial_8.1\mkl_8.1_serial\ia32\bin". Do I need  to set the environment variable?
> > Hope your help.
> > Best,
> > Yixun
