about mkl_p4p.dll not found
Yixun Liu yxliu at fudan.edu.cn
Sat May 26 04:35:55 CDT 2007
My program is based on PETSC. Its compiler and link is ok, but when execute a error was generated. The error is:
"MKL FATAL ERROR: Cannot load neither mkl_p4p.dll nor mkl_def.dllPress any key to continue"
I can find the mkl_p4p.dll in  "D:\MyVC\petsc-2.3.2-p3\externalpackages\w_mkl_serial_p_8.1.001\mkl_serial_8.1\mkl_8.1_serial\ia32\bin". Do I need  to set the environment variable?
Hope your help.
Best,
Yixun
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20070526/552bda86/attachment.htm>
