Verry time consuming first matrix assembly
Wed May 23 08:22:19 CDT 2007
Please send the results of -info -log_summary.
    Matt
On 5/23/07, devteam <devteam at transvalor.com> wrote:
> Hello,
> I have a FEM code that perform with several meshes. We handle
> interactions/contacts between bodies/meshes by assembling coupling terms
> between the « contact » nodes of the meshes.
> I have a very large bandwidth : The numbering of the whole problem is done
> mesh by mesh (my problem is of size 4*N where N is the total number of node
> and N = N1 + N2 + .. + Nq with Nq the number of nodes of mesh q. Nodes of
> mesh q are numbered from N1+N2 + .. + N(q-1) + 1 to N1+N2+..+Nq)
> Typically N # 100000 to 1000000.
> The matrix is a MPIBAIJ one and the d_nnz and o_nnz info are specified when
> created.
> It is filled using MatSetValuesBlockedLocal in mode ADD_VALUES.
> At each increment of my time step scheme, the connections between mesh nodes
> may change and I have to rebuild the matrix.
> It appears that the CPU required for the first matrix assembly is very large
> (three to four times the CPU for 1 system solve) and depend on the number of
> meshes : if I have only one mesh of an equivalent size the assembly CPU
> remain almost zero.
> So I wonder what is causing the assembly to last so much ? I was thinking
> that the system solve would have been longer because of my large bandwidth
> but I don't understand why it is the matrix assembly that last so much.
> I have investigated using Mat_info but all seems to be correct : the number
> of malloc during MatSetValue is always zero and I have a ratio non zero used
> / non zero allocated between 1% and 10% (same ratio than when I have only
> one mesh).
> I have tested using a simple SOR preconditionner instead of ILU, wondering
> if it was the precond assembly that last long because of the bandwidth, but
> it does not change anything !
> Thanks a lot for any remarks or any tip.
> Best regards,
> Etienne Perchat
experiments is infinitely more interesting than any results to which
their experiments lead.
-- Norbert Wiener
