Verry time consuming first matrix assembly
devteam devteam at transvalor.com
Wed May 23 07:24:56 CDT 2007
Hello,
I have a FEM code that perform with several meshes. We handle
interactions/contacts between bodies/meshes by assembling coupling terms
between the « contact » nodes of the meshes.
I have a very large bandwidth : The numbering of the whole problem is done
mesh by mesh (my problem is of size 4*N where N is the total number of node
and N = N1 + N2 + .. + Nq with Nq the number of nodes of mesh q. Nodes of
mesh q are numbered from N1+N2 + .. + N(q-1) + 1 to N1+N2+..+Nq)
Typically N # 100000 to 1000000.
The matrix is a MPIBAIJ one and the d_nnz and o_nnz info are specified when
created.
It is filled using MatSetValuesBlockedLocal in mode ADD_VALUES.
At each increment of my time step scheme, the connections between mesh nodes
may change and I have to rebuild the matrix.
It appears that the CPU required for the first matrix assembly is very large
(three to four times the CPU for 1 system solve) and depend on the number of
meshes : if I have only one mesh of an equivalent size the assembly CPU
remain almost zero.
So I wonder what is causing the assembly to last so much ? I was thinking
that the system solve would have been longer because of my large bandwidth
but I don't understand why it is the matrix assembly that last so much.
I have investigated using Mat_info but all seems to be correct : the number
of malloc during MatSetValue is always zero and I have a ratio non zero used
/ non zero allocated between 1% and 10% (same ratio than when I have only
one mesh).
I have tested using a simple SOR preconditionner instead of ILU, wondering
if it was the precond assembly that last long because of the bandwidth, but
it does not change anything !
Thanks a lot for any remarks or any tip.
Best regards,
Etienne Perchat
