Is it possible to build one Petsc that works for both C and C++?
Shi Jin jinzishuai at yahoo.com
Sun Jun 17 11:22:54 CDT 2007
Great!
Thanks a lot!
Shi
--- Matthew Knepley <knepley at gmail.com> wrote:
> This is an MPICH problem. From mpicxx.h:
> // There is a name conflict between stdio.h and the
> MPI C++ binding
> // with respect to the names SEEK_SET, SEEK_CUR, and
> SEEK_END.  MPI
> // wants these in the MPI namespace, but stdio.h
> will #define these
> // to integer values.  #undef'ing these can cause
> obscure problems
> // with other include files (such as iostream), so
> we instead use
> // #error to indicate a fatal error.  Users can
> either #undef
> // the names before including mpi.h or include mpi.h
> *before* stdio.h
> // or iostream.
> #ifndef MPICH_IGNORE_CXX_SEEK
> #ifdef SEEK_SET
> #error "SEEK_SET is #defined but must not be for the
> C++ binding of MPI"
> //#undef SEEK_SET
> #endif
> #ifdef SEEK_CUR
> #error "SEEK_CUR is #defined but must not be for the
> C++ binding of MPI"
> //#undef SEEK_CUR
> #endif
> #ifdef SEEK_END
> //#undef SEEK_END
> #error "SEEK_END is #defined but must not be for the
> C++ binding of MPI"
> #endif
> #endif
> I recommend not including stdio.h yourself. PETSc
> will do it.
>    Matt
> On 6/17/07, Shi Jin <jinzishuai at yahoo.com> wrote:
> > But this is what I got trying to compile my C
> petsc
> > code with the C++ build:
> > In file included from
/mnt/200g/works/MyWork/PETSc/C++PETSc/petsc-2.3.3-p3/externalpackages/mpich2-1.0.5p4/linux-gnu-cxx-debug/include/mpi.h:1104,
> >                  from spAF_incl.h:20,
> >                  from spAF_analyt.h:11,
> >                  from spAF_analyt.c:11:
/mnt/200g/works/MyWork/PETSc/C++PETSc/petsc-2.3.3-p3/externalpackages/mpich2-1.0.5p4/linux-gnu-cxx-debug/include/mpicxx.h:26:2:
> > error: #error "SEEK_SET is #defined but must not
> be
> > for the C++ binding of MPI"
/mnt/200g/works/MyWork/PETSc/C++PETSc/petsc-2.3.3-p3/externalpackages/mpich2-1.0.5p4/linux-gnu-cxx-debug/include/mpicxx.h:30:2:
> > error: #error "SEEK_CUR is #defined but must not
> be
/mnt/200g/works/MyWork/PETSc/C++PETSc/petsc-2.3.3-p3/externalpackages/mpich2-1.0.5p4/linux-gnu-cxx-debug/include/mpicxx.h:35:2:
> > error: #error "SEEK_END is #defined but must not
> be
> > make: *** [spAF_analyt.o] Error 1
> > Did you do anything special? I am using GCC.
> > Thanks.
> > Shi
> wrote:
> > > > Hi,
> > > > I am learning the unstructured part of Petsc,
> > > which
> > > > naturally uses C++(at least the sample I am
> > > studying
> > > > is C++). On the other hand, my old Petsc codes
> are
> > > all
> > > > written in C.
> > > > I found that once I build the Petsc with C++,
> the
> > > old
> > > > C codes cannot be compiled since it is trying
> to
> > > use
> > > > mpicxx to compile the .c source files.
> However, I
> > > do
> > > This should be no problem. I do it all the time.
> Any
> > > C++
> > > compiler can compile C just fine.
> > >   Matt
> > > > see after the configuration stage that there
> is a
> > > > list:
> > > > C compiler: mpicc
> > > > C++ compiler: mpicxx
> > > > Fortran compiler: mpif77
> > > > Is it possible to instruct Petsc to use the
> > > > corresponding  compiler for different source
> > > codes?
> > > > Thanks a lot.
> > > > PS. This is how I configured my
> Petsc-2.3.3-p3:
> > > > ./config/configure.py --with-cc=gcc
> --with-fc=g77
> > > > --with-cxx=g++ --download-f-blas-lapack=1
> > > > --download-mpich=1 --with-clanguage=cxx
> > > --with-sieve=1
> > > > --download-boost=1 --download-chaco
> > > > --download-parmetis   --download-fiat
> > > --download-generator
____________________________________________________________________________________
> > > > Get the Yahoo! toolbar and be alerted to new
> email
> > > wherever you're surfing.
http://new.toolbar.yahoo.com/toolbar/features/mail/index.php
> > > What most experimenters take for granted before
> they
> > > begin their
> > > experiments is infinitely more interesting than
> any
> > > results to which
> > > their experiments lead.
> > > -- Norbert Wiener
> > You snooze, you lose. Get messages ASAP with
> AutoCheck
> > in the all-new Yahoo! Mail Beta.
http://advision.webevents.yahoo.com/mailbeta/newmail_html.html
> What most experimenters take for granted before they
> begin their
> experiments is infinitely more interesting than any
> results to which
> -- Norbert Wiener
Food fight? Enjoy some healthy debate
in the Yahoo! Answers Food & Drink Q&A.
http://answers.yahoo.com/dir/?link=list&sid=396545367
