Error compile petsc-dev
Sun Jun 10 22:04:02 CDT 2007
  Please send to petsc-maint at mcs.anl.gov instead of petsc-users
The makefile system was changed slightly in petsc-dev see
http://www-unix.mcs.anl.gov/web-mail-archive/lists/petsc-dev/2007/06/msg00003.html
 Most likely you have not set PETSC_ARCH
   Barry
On Sun, 10 Jun 2007, Shi Jin wrote:
> Hi,
> Since I wanted to try Barry's implementation on the
> "Do not ignore errors in Makefile" issue, I checked
> out petsc-dev (both the Mercurial and the nightly tar
> ball).
> However, I had the same errors during make:
> home/seki/mywork/PETSc/petsc-dev/conf/variables:119:
> /home/seki/mywork/PETSc/petsc-dev//conf/petscconf: No
> such file or directory
> /home/seki/mywork/PETSc/petsc-dev/conf/rules:808:
> /home/seki/mywork/PETSc/petsc-dev//conf/petscrules: No
> make: *** No rule to make target
> `/home/seki/mywork/PETSc/petsc-dev//conf/petscrules'.
> Stop.
> Please help.
> Thanks.
> Shi
> ____________________________________________________________________________________
> Get the Yahoo! toolbar and be alerted to new email wherever you're surfing.
> http://new.toolbar.yahoo.com/toolbar/features/mail/index.php
