libc.lib error when linking test examples
Fri Jun 1 11:18:43 CDT 2007
On Sat, 2 Jun 2007, Ben Tay wrote:
> yes it's compaq vf. so how do i change the pcc_linker to use 'win32fe f90`?
> can u elaborate?
- edit bmake/$PETSC_ARCH/petscconf
- look for 'PCC_LINKER = win32fe cl ............'
- change 'cl' to 'f90'
> but anyway, maybe it's not so impt now. i just compiled 2.3.2p8 and
> it worked. moreover, i tried to run my own code in vf, replacing the
> 2.3.2p8files with the 2.3.3p0 and it worked.
Ok - If you are using project files - then you don't need to fix the
makefiles.
satish
> On 6/1/07, Satish Balay <balay at mcs.anl.gov> wrote:
> > One way to do this is to manualy edit bmake/$PETSC_ARCH/petscconf and
> > change PCC_LINKER to use 'win32fe f90'
