libc.lib error when linking test examples
Ben Tay zonexo at gmail.com
Fri Jun 1 11:13:23 CDT 2007
yes it's compaq vf. so how do i change the pcc_linker to use 'win32fe f90`?
can u elaborate?
but anyway, maybe it's not so impt now. i just compiled 2.3.2p8 and it
worked. moreover, i tried to run my own code in vf, replacing the
2.3.2p8files with the
2.3.3p0 and it worked.
On 6/1/07, Satish Balay <balay at mcs.anl.gov> wrote:
> Is this compaq visual fortran?
> You'll have to use FLINKER for c examples as well. [because of fortran
> blas - and only compaq f90 know how to do the linking correctly - when
> fortran objects are involved]. Configure can't handle this case
> automatically.
> One way to do this is to manualy edit bmake/$PETSC_ARCH/petscconf and
> change PCC_LINKER to use 'win32fe f90'
> Satish
> On Fri, 1 Jun 2007, Ben Tay wrote:
> > Hi,
> > I'm using ms vc++ and vf in windows xp. I tried to compile PETSc 2.3.3p0
> > Running configure has no problem. Compiling seems ok but in the last
> part
> > when it tried to test examples, the error is
> > --------------Error detected during compile or
> link!-----------------------
> > See
> http://www.mcs.anl.gov/petsc/petsc-2/documentation/troubleshooting.html
> > /codes/petsc-2.3.3-p0/bin/win32fe/win32fe cl -o ex19.o -c -MT -Z7
> > -I/codes/petsc-2.3.3-p0 -I/codes/petsc-2.3.3-p0/bmake/
> > win32_mpi -I/codes/petsc-2.3.3-p0/include
> > -I/cygdrive/d/cygwin/codes/MPICH/SDK/include
> > -D__SDIR__="src/snes/examples/tut
> > orials/" ex19.c
> > ex19.c
> > /codes/petsc-2.3.3-p0/bin/win32fe/win32fe cl -MT -Z7  -o ex19
> > ex19.o-L/codes/petsc-
> > 2.3.3-p0/lib/win32_mpi -L/codes/pet
> > sc-2.3.3-p0/lib/win32_mpi -lpetscsnes -lpetscksp -lpetscdm -lpetscmat
> > -lpetscvec -lpetsc   /cygdrive/d/cygwin/codes/MPIC
> > H/SDK/lib/mpich.lib
> > -L/codes/petsc-2.3.3-p0/externalpackages/fblaslapack/win32_mpi
> > ges/fblaslapack/win32_mpi -lflapack
> > p0/externalpackages/fblaslapack/win32_mpi -lfblas Gdi32.lib User32.lib
> > Advapi32.lib Kernel32.lib Ws2_32.lib  -L'/cygdriv
> > e/c/Program Files/Microsoft Visual Studio/DF98/LIB'
> > dformt.lib(matherr.obj) : error LNK2005: __matherr already defined in
> > LIBCMT.lib(matherr.obj)
> > libc.lib(crt0dat.obj) : error LNK2005: __cinit already defined in
> LIBCMT.lib
> > (crt0dat.obj)
> > libc.lib(crt0dat.obj) : error LNK2005: _exit already defined in
> LIBCMT.lib(
> > crt0dat.obj)
> > libc.lib(crt0dat.obj) : error LNK2005: __exit already defined in
> LIBCMT.lib(
> > crt0dat.obj)
> > libc.lib(crt0dat.obj) : error LNK2005: __cexit already defined in
> LIBCMT.lib
> > (crt0dat.obj)
> > libc.lib(crt0dat.obj) : error LNK2005: __c_exit already defined in
> > LIBCMT.lib(crt0dat.obj)
> > libc.lib(crt0dat.obj) : error LNK2005: __C_Exit_Done already defined in
> > libc.lib(crt0dat.obj) : error LNK2005: __C_Termination_Done already
> defined
> > in LIBCMT.lib(crt0dat.obj)
> > libc.lib(crt0dat.obj) : error LNK2005: __exitflag already defined in
> > libc.lib(crt0dat.obj) : error LNK2005: __wpgmptr already defined in
> > libc.lib(crt0dat.obj) : error LNK2005: __pgmptr already defined in
> > libc.lib(crt0dat.obj) : error LNK2005: ___winitenv already defined in
> > libc.lib(crt0dat.obj) : error LNK2005: __wenviron already defined in
> > libc.lib(crt0dat.obj) : error LNK2005: ___initenv already defined in
> > libc.lib(crt0dat.obj) : error LNK2005: __environ already defined in
> > libc.lib(crt0dat.obj) : error LNK2005: ___wargv already defined in
> > libc.lib(crt0dat.obj) : error LNK2005: ___argv already defined in
> LIBCMT.lib
> > (crt0dat.obj)
> > libc.lib(crt0dat.obj) : error LNK2005: ___argc already defined in
> LIBCMT.lib
> > (crt0dat.obj)
> > libc.lib(crt0dat.obj) : error LNK2005: __winminor already defined in
> > libc.lib(crt0dat.obj) : error LNK2005: __winmajor already defined in
> > libc.lib(crt0dat.obj) : error LNK2005: __winver already defined in
> > libc.lib(crt0dat.obj) : error LNK2005: __osver already defined in
> LIBCMT.lib
> > (crt0dat.obj)
> > libc.lib(crt0dat.obj) : error LNK2005: __umaskval already defined in
> > LINK : warning LNK4098: defaultlib "libc.lib" conflicts with use of
> other
> > libs; use /NODEFAULTLIB:library
> > d:\cygwin\codes\PETSC-~1.3-P\src\snes\examples\TUTORI~1\ex19.exe : fatal
> > error LNK1169: one or more multiply defined sym
> > bols found
> > make[3]: [ex19] Error 2 (ignored)
> > /usr/bin/rm -f ex19.o
> > My configure command is :
> > ./config/configure.py --with-cc='win32fe cl' --with-fc='win32fe f90'
> > --download-f-blas-lapack=1 LIBS="-L'/cygdrive/c/Program Files/Microsoft
> > Visual Studio/DF98/LIB'" --with-x=0
> > --with-mpi-dir=/cygdrive/d/cygwin/codes/MPICH/SDK
> > Hope someone can help.
> > Thank you.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20070602/af3fc814/attachment.htm>
