PETSc compiler
li pan li76pan at yahoo.com
Tue Jul 24 01:19:36 CDT 2007
hi Barry,
I also have interest about how to use petsc under
visual studio. Can you explain a little bit how to do
it? I'm using cygwin. Cygwin generates libraries for
linux environment. Is that right?
pan
--- Barry Smith <bsmith at mcs.anl.gov> wrote:
>   No, the cygwin shell and its make are used to
> configure
> and compile all of the PETSc libraries.
>   Once the libraries are built you can switch to
> Developers Studio or what you want to use to build
> your
> application.
>     Barry
> On Fri, 20 Jul 2007, Sumit Vaidya wrote:
> > Well I am planning to use icl and ifort compilers
> on windows.
> > Is it possible to build it without Cygwin?
> > Sumit
> > -----Original Message-----
> > From: owner-petsc-users at mcs.anl.gov
> [mailto:owner-petsc-users at mcs.anl.gov]
> > On Behalf Of Satish Balay
> > Sent: Thursday, July 19, 2007 8:35 PM
> > To: petsc-users at mcs.anl.gov
> > Subject: RE: PETSc compiler
> > On Thu, 19 Jul 2007, Sumit Vaidya wrote:
> > > I am sorry.
> > > I want to build it on windows. I forgot to
> mention that. On windows I will
> > > not be having "configure.py" script.
> > You'll have to follow the installation
> instructions from:
http://www-unix.mcs.anl.gov/petsc/petsc-as/documentation/installation.html
> > you'll need to run config/configure.py [from
> cygwin] on windows -
> > as per the installation instructions.
> > Sepecifically - check the instruction in
> 'Additional Microsoft Windows
> > Notes:' section.
> > BTW: what compilers [c, fortran] do you plan to
> use on windows?
> > Satish
> > DISCLAIMER
> > This e-mail may contain privileged and
> confidential information which is the property of
> Persistent Systems Pvt. Ltd. It is intended only for
> the use of the individual or entity to which it is
> addressed. If you are not the intended recipient,
> you are not authorized to read, retain, copy, print,
> distribute or use this message. If you have received
> this communication in error, please notify the
> sender and delete all copies of this message.
> Persistent Systems Pvt. Ltd. does not accept any
> liability for virus infected mails.
____________________________________________________________________________________
Looking for a deal? Find great prices on flights and hotels with Yahoo! FareChase.
http://farechase.yahoo.com/
