PETSc compiler
Fri Jul 20 07:57:26 CDT 2007
  No, the cygwin shell and its make are used to configure
and compile all of the PETSc libraries.
  Once the libraries are built you can switch to
Developers Studio or what you want to use to build your
application.
    Barry
On Fri, 20 Jul 2007, Sumit Vaidya wrote:
> Well I am planning to use icl and ifort compilers on windows.
> Is it possible to build it without Cygwin?
> Sumit
> -----Original Message-----
> From: owner-petsc-users at mcs.anl.gov [mailto:owner-petsc-users at mcs.anl.gov]
> On Behalf Of Satish Balay
> Sent: Thursday, July 19, 2007 8:35 PM
> To: petsc-users at mcs.anl.gov
> Subject: RE: PETSc compiler
> On Thu, 19 Jul 2007, Sumit Vaidya wrote:
> > I am sorry.
> > I want to build it on windows. I forgot to mention that. On windows I will
> > not be having "configure.py" script.
> You'll have to follow the installation instructions from:
> http://www-unix.mcs.anl.gov/petsc/petsc-as/documentation/installation.html
> you'll need to run config/configure.py [from cygwin] on windows -
> as per the installation instructions.
> Sepecifically - check the instruction in 'Additional Microsoft Windows
> Notes:' section.
> BTW: what compilers [c, fortran] do you plan to use on windows?
> Satish
> DISCLAIMER
> This e-mail may contain privileged and confidential information which is the property of Persistent Systems Pvt. Ltd. It is intended only for the use of the individual or entity to which it is addressed. If you are not the intended recipient, you are not authorized to read, retain, copy, print, distribute or use this message. If you have received this communication in error, please notify the sender and delete all copies of this message. Persistent Systems Pvt. Ltd. does not accept any liability for virus infected mails.
