understanding the output from -info
Lisandro Dalcin dalcinl at gmail.com
Sat Feb 10 22:03:20 CST 2007
On 2/10/07, Ben Tay <zonexo at gmail.com> wrote:
> In other words, for my CFD code, it is not possible to parallelize it
> effectively because the problem is too small?
> Is these true for all parallel solver, or just PETSc? I was hoping to reduce
> the runtime since mine is an unsteady problem which requires many steps to
> reach a periodic state and it takes many hours to reach it.
Can you describe your specific application and how are you solving it?
As Barry said, your need-for-speed is not likely to be solved by
running in parallel.
Lisandro Dalcín
Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
PTLC - Güemes 3450, (3000) Santa Fe, Argentina
Tel/Fax: +54-(0)342-451.1594
