PETSc runs slower on a shared memory machine than on a cluster
Mon Feb 5 18:33:15 CST 2007
A couple of comments:
- with the dual core opteron - the memorybandwith per core is now
reduced by half - so the performance suffers.  However memory
bandwidth across CPUs is scalable. [6.4 Gb/s per each node or 3.2Gb/s
per core]
- Current generation Intel Core 2 duo appears to claim having
sufficient bandwidth [15.3Gb/s per node = 7.6Gb/s per core?] so from
this bandwidth number - this chip might do better than the AMD
chip. However I'm not sure if there is a SMP with this chip - which
has scalable memory system [across say 8 nodes - as you currently
have..]
- Older intel SMP boxes has a single memory bank shared across all the
CPUs [so effective bandwidth per CPU was pretty small. Optrons'
scalable architecture looked much better than the older intel SMPs]
- From previous log_summary - part of the inefficiency of the SMP box
[when compared to the cluster] was in the MPI performance. Do you
still see this effect in the '-np 8' runs? If so this could be the
[part of the] reason for this 30% reduction in performance.
Satish
On Mon, 5 Feb 2007, Shi Jin wrote:
> Hi there,
> I have made some new progress on the issue of SMP
> performance. Since my shared memory machine is a 8
> dual-core Opteron machine. I think the two cores on a
> single CPU chip shares the memory bandwidth.
> Therefore, if I can avoid using the same core on the
> chip, I can get some performance improvement. Indeed,
> I am able to do this by the linux command taskset.
> Here is what I did:
> petscmpirun -n 8 taskset -c 0,2,4,6,8,10,12,14 ../spAF
> This way, I specifically ask the processes to be run
> on the first core on the CPUs.
> By doing this, my performance is doubled compared with
> the simple petscmpirun -n 8 ../spAF
> So this test shows that we do suffer from the
> competition of resources of multiple processes,
> especially when we use 16 processes.
> However, I should point out that even with the help
> taskset, the shared-memory performance is still 30%
> less than  that on the cluster.
> I am not sure whether this problem exists specifically
> for the AMD machines or it applys to any shared-memory
> architecture.
> Thanks.
> Shi
> --- Shi Jin <jinzishuai at yahoo.com> wrote:
> > Hi there,
> > I am fairly new to PETSc but have 5 years of MPI
> > programming already. I recently took on a project of
> > analyzing a finite element code written in C with
> > PETSc.
> > I found out that on a shared-memory machine (60GB
> > RAM,
> > 16    CPUS), the code runs around 4 times slower
> > than
> > on a distributed memory cluster (4GB Ram,
> > 4CPU/node),
> > although they yield identical results.
> > There are 1.6Million finite elements in the problem
> > so
> > it is a fairly large calculation. The total memory
> > used is 3GBx16=48GB.
> > Both the two systems run Linux as OS and the same
> > code
> > is compiled against the same version of MPICH-2 and
> > PETSc.
> > The shared-memory machine is actually a little
> > faster
> > than the cluster machines in terms of single process
> > runs.
> > I am surprised at this result since we usually tend
> > to
> > think that shared-memory would be much faster since
> > the in-memory operation is much faster that the
> > network communication.
> > However, I read the PETSc FAQ and found that "the
> > speed of sparse matrix computations is almost
> > totally
> > determined by the speed of the memory, not the speed
> > of the CPU".
> > This makes me wonder whether the poor performance of
> > my code on a shared-memory machine is due to the
> > competition of different process on the same memory
> > bus. Since the code is still MPI based, a lot of
> > data
> > are moving around inside the memory. Is this a
> > reasonable explanation of what I observed?
> > Thank you very much.
> > Shi
> ____________________________________________________________________________________
> > Do you Yahoo!?
> > Everyone is raving about the all-new Yahoo! Mail
> > beta.
> > http://new.mail.yahoo.com
> Expecting? Get great news right away with email Auto-Check.
> Try the Yahoo! Mail Beta.
> http://advision.webevents.yahoo.com/mailbeta/newmail_tools.html
