a current state of python bindings
Ondrej Certik ondrej at certik.cz
Thu Apr 26 05:52:16 CDT 2007
Hi Mads,
yes, I know about the bindings from elefant, but they seem to be just
a direct translation of C commands to Python, but petsc4py seem to be
more pythonic. I know that there is no documentation to them, but
reading the sources (there are a lot of docstrings) was enough for me.
If you want to look at an example:
http://grainmodel.googlecode.com/svn/trunk/femlib/
look into the "__init__.py", where I set up paths for petsc4py, and
then into "fem.py", where I import petsc4py and construct matrices and
solve them.
But I just wanted to check what people at this mailinglist use.
Experimenting with petsc in python is just fun.
And as to the installation - there are many options to the petsc
package, so it's difficult (almost impossible) to create one (binary)
package for all, on the other hand, when developing my program, I want
petsc to just work (I can play with the options later). I use Debian,
thus I just want to "apt-get install petsc-dev" to have a functioning
petsc installation and then "apt-get install python-petsc" to have
functioning python bindings. So my contribution to this is to create
the python-petsc Debian package and get it into Debian.
Ondrej
On 4/26/07, Mads Fredrik Skoge Hoel <mfhoel at ifi.uio.no> wrote:
> Hi Ondrej,
> I tried out petsc4py, i could not find any documentation. I used alot of
> time just trying to get it to work. And without documentation, i tried to
> guess, and finally managed to construct a Mat object. It seems that
> petsc4py is currently in an experimental version.
> You might also want to have a look at PyPetsc:
> https://elefant.developer.nicta.com.au/documentation/userguide/PyPetscManual.pdf
> and
> https://elefant.developer.nicta.com.au/developer/designdocs/PyPetscDesignRef.pdf
> I have not tried the PyPetsc, but at least there is documentation.
> Regards,
> Mads
> > On Thu, 26 Apr 2007, Ondrej Certik wrote:
> >> Hi,
> >> I am using PETSc from Python. I read the post:
> >> http://www-unix.mcs.anl.gov/web-mail-archive/lists/petsc-users/2006/08/msg00090.html
> >> I am currently using the petsc4py, but unfortunately, they don't seem
> >> to have uptodate webpage. The most recent version, that works with
> >> petsc 2.3.2 can be found here:
> >> http://cheeseshop.python.org/pypi/petsc4py/0.7.2
> >> However, there are some bindings inside the petsc tarball, but I
> >> didn't find any documentation for them - are they deprecated?
> >   Yes.
> >> Also, I would like to create a debian package "python-petsc" with
> >> python bindings to petsc (and get it to debian main distribution), so
> >> I wanted to check with you, what the most advanced python bindigs
> >> actually are (and which I should package).
> >   At this time we are recommending petsc4py.
> >    Barry
> >> Thanks,
> >> Ondrej
