a current state of python bindings
Mads Fredrik Skoge Hoel mfhoel at ifi.uio.no
Thu Apr 26 05:09:18 CDT 2007
Hi Ondrej,
I tried out petsc4py, i could not find any documentation. I used alot of
time just trying to get it to work. And without documentation, i tried to
guess, and finally managed to construct a Mat object. It seems that
petsc4py is currently in an experimental version.
You might also want to have a look at PyPetsc:
https://elefant.developer.nicta.com.au/documentation/userguide/PyPetscManual.pdf
and
https://elefant.developer.nicta.com.au/developer/designdocs/PyPetscDesignRef.pdf
I have not tried the PyPetsc, but at least there is documentation.
Mads
> On Thu, 26 Apr 2007, Ondrej Certik wrote:
>> Hi,
>> I am using PETSc from Python. I read the post:
>> http://www-unix.mcs.anl.gov/web-mail-archive/lists/petsc-users/2006/08/msg00090.html
>> I am currently using the petsc4py, but unfortunately, they don't seem
>> to have uptodate webpage. The most recent version, that works with
>> petsc 2.3.2 can be found here:
>> http://cheeseshop.python.org/pypi/petsc4py/0.7.2
>> However, there are some bindings inside the petsc tarball, but I
>> didn't find any documentation for them - are they deprecated?
>   Yes.
>> Also, I would like to create a debian package "python-petsc" with
>> python bindings to petsc (and get it to debian main distribution), so
>> I wanted to check with you, what the most advanced python bindigs
>> actually are (and which I should package).
>   At this time we are recommending petsc4py.
>    Barry
>> Thanks,
>> Ondrej
