HYPRE with multiple variables
Wed Apr 25 16:59:46 CDT 2007
  Nicolas,
   I have added support for both 1 and/or 2 to petsc-dev
http://www-unix.mcs.anl.gov/petsc/petsc-as/developers/index.html
The two new options are -pc_hypre_boomeramg_nodal_coarsen and
-pc_hypre_boomeramg_nodal_relaxation <optional:n) where the optional
argument n indicates the levels which the SmoothNumLevels() sets.
I have not tested the code so please let me know what problems you have.
  Allison,
    Thank you very much for the clarifications.
   Barry
On Wed, 25 Apr 2007, Allison Baker wrote:
> Hi Barry and Nicolas,
> To clarify,
> HYPRE_BoomerAMGSetNumFunctions(solver, int num_functions) tells AMG to solve a
> system of equations with the specified number of functions/unknowns. The
> default AMG scheme to solve a PDE system is the "unknown" approach. (The
> coarsening and interpolation are determined by looking at each
> unknown/function independently - therefore you can imagine that the coarse
> grids are generally not the same for each variable. This approach generally
> works well unless you have strong coupling between unknowns.)
> HYPRE_BOOMERAMGSetNodal(solver, int nodal ) tells AMG to coarsen such that
> each variable has the same coarse grid - sometimes this is more "physical" for
> a particular problem. The value chosen here for nodal determines how strength
> of connection is determined between the coupled system.  I suggest setting
> nodal = 1, which uses a Frobenius norm.  This does NOT tell AMG to use nodal
> relaxation.
> If you want to use nodal relaxation in hypre there are two choices:
> (1) If you call  HYPRE_BOOMERAMGSetNodal, then you can additionally do nodal
> relaxation via the schwarz smoother option in hypre.  I did not implement this
> in the Petsc interface, but it could be done easy enough. The following four
> functions need to be called:
>      HYPRE_BoomerAMGSetSmoothType(solver, 6);
>      HYPRE_BoomerAMGSetDomainType(solver, 1);
>      HYPRE_BoomerAMGSetOverlap(solver, 0);
>      HYPRE_BoomerAMGSetSmoothNumLevels(solver, num_levels);  (Set num_levels
> to number of levels on which you  want nodal smoothing, i.e. 1=just the fine
> grid, 2= fine grid and the grid below, etc.  I find that doing nodal
> relaxation on just the finest level is generally sufficient.)  Note that the
> interpolation scheme used will be the same as in the unknown approach - so
> this is what we call a hybrid systems method.
> (2) You can do both nodal smoothing and a nodal interpolation scheme.  While
> this is currently implemented in 2.0.0, it is not advertised (i.e., mentioned
> at all in the user's manual) because it is not yet implemented very
> efficiently (the fine grid matrix is converted to a block matrix - and both
> are stored), and we have not found it to be as effective as advertised
> elsewhere (this is an area of current research for us)..... If you want to try
> it anyway, let me know and I will provide more info.
> Hope this helps,
> Allison
> Barry Smith wrote:
> >   Nicolas,
> > On Wed, 25 Apr 2007, Nicolas Bathfield wrote:
> > > Dear Barry,
> > > Using MatSetBlockSize(A,5) improved my results greatly. Boomemramg is now
> > > solving the system of equations.
> >    Good
> > > Still, the equations I solve are coupled, and my discretization scheme is
> > > meant for a non-segregated solver. As a consequence (I believe), boomeramg
> > > still diverges.
> >   How can "Boomeramg be now solving the system of equations" but also
> > diverge? I am so confused.
> > >  I would therefore like to use the nodal relaxation in
> > > boomeramg (the hypre command is HYPRE_BOOMERAMGSetNodal) in order to
> > > couple the coarse grid choice for all my variables.
> >   I can add this this afternoon.
> >   I have to admit I do not understand the difference between
> > HYPRE_BOOMERAMGSetNodal() and hypre_BoomerAMGSetNumFunctions(). Do you?
> >    Barry
> > > How can I achieve this from PETSc?
> > > Best regards,
> > > Nicolas
> > > >   From PETSc MPIAIJ matrices you need to set the block size of the
> > > > matrix
> > > > with MatSetBlockSize(A,5) after you have called MatSetType() or
> > > > MatCreateMPIAIJ(). Then HYPRE_BoomerAMGSetNumFunctions() is
> > > > automatically
> > > > called by PETSc.
> > > >    Barry
> > > > The reason this is done this way instead of as
> > > > -pc_hypre_boomeramg_block_size <bs> is the idea that hypre will use the
> > > > properties of the matrix it is given in building the preconditioner so
> > > > the user does not have to pass those properties in seperately directly
> > > > to hypre.
> > > > On Fri, 13 Apr 2007, Shaman Mahmoudi wrote:
> > > > > Hi,
> > > > > int HYPRE_BoomerAMGSetNumFunctions (.....)
> > > > > sets the size of the system of PDEs.
> > > > > With best regards, Shaman Mahmoudi
> > > > > On Apr 13, 2007, at 2:04 PM, Shaman Mahmoudi wrote:
> > > > > > Hi Nicolas,
> > > > > > You are right. hypre has changed a lot since the version I used.
> > > > > > I found this interesting information:
> > > > > > int HYPRE_BOOMERAMGSetNodal(....)
> > > > > > Sets whether to use the nodal systems version. Default is 0.
> > > > > > Then information about smoothers:
> > > > > > One interesting thing there is this,
> > > > > > HYPRE_BoomerAMGSetDomainType(....)
> > > > > > 0 - each point is a domain (default)
> > > > > > 1 each node is a domain (only of interest in systems AMG)
> > > > > > 2 ....
> > > > > > I could not find how you define the nodal displacement ordering. But
> > > > > it
> > > > > > should be there somewhere.
> > > > > > I read the reference manual for hypre 2.0
> > > > > > On Apr 13, 2007, at 1:40 PM, Nicolas Bathfield wrote:
> > > > > > > Dear Shaman,
> > > > > > > As far as I could understand, there is a BoomerAMG?s systems AMG
> > > > > version
> > > > > > > available. This seems to be exactly what I am looking for, but I
> > > > > just
> > > > > > > don't know how to access it, either through PETSc or directly.
> > > > > > > Best regards,
> > > > > > > Nicolas
> > > > > > > > Hi,
> > > > > > > > You want to exploit the structure of the model?
> > > > > > > > As far as I know, boomeramg can not treat a set of rows or
> > > > > > > > blocks
> > > > > as
> > > > > > > > a molecule,  a so called block-smoother?
> > > > > > > > ML 2.0 smoothed aggregation does support it.
> > > > > > > > On Apr 13, 2007, at 10:45 AM, Nicolas Bathfield wrote:
> > > > > > > > > Hi,
> > > > > > > > > I am solving the Navier-stokes equations and try to use Hypre
> > > > > > > > > as
> > > > > > > > > preconditioner.
> > > > > > > > > Until now, I used PETSc as non-segregated solver and it worked
> > > > > > > > > perfectly.
> > > > > > > > > Things got worse when I decided to use Boomeramg (Hypre).
> > > > > > > > > As I solve a system of PDEs,  each cell is represented by 5
> > > > > > > > > rows
> > > > > in my
> > > > > > > > > matrix (I solve for 5 variables). PETSc handles that without
> > > > > problem
> > > > > > > > > apparently, but the coarsening scheme of Boomeramg needs more
> > > > > input in
> > > > > > > > > order to work properly.
> > > > > > > > > Is there an option in PETSc to tell HYPRE that we are dealing
> > > > > with a
> > > > > > > > > system of PDEs? (something like:  -pc_hypre_boomeramg_...)
> > > > > > > > > Thanks for your help.
> > > > > > > > > Best regards,
> > > > > > > > > Nicolas
> > > > > > > > > Nicolas BATHFIELD
> > > > > > > > > Chalmers University of Technology
> > > > > > > > > Shipping and Marine Technology
> > > > > > > > > phone: +46 (0)31 772 1476
> > > > > > > > > fax:   +46 (0)31 772 3699
> > > > > > > Nicolas BATHFIELD
