CSR Sparse Matrix Query
Tue Apr 24 07:55:21 CDT 2007
   In petsc-dev http://www-unix.mcs.anl.gov/petsc/petsc-as/developers/index.html
there is code that allows creating a matrix/linear system on one process and
solving it in parallel, See PCType PCOPENMP
http://www-unix.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-dev/docs/manualpages/PC/PCOPENMP.html
This is a quick-and-dirty stop-gap way of having a parallel code (where your
code is not parallel). It is not a long term solution but can get good speedup
for several processes.
   Barry
 There is also a low-level routine that takes a seqaij and distributes it to a
parallel form called MatDistribute_MPIAIJ(), but using PCOPENMP is much easier
to use.
On Tue, 24 Apr 2007, Dr. Timothy Stitt wrote:
> Matt,
> Thanks for the reply. I was hoping that there was some sort of automatic
> distribution from the global operator matrix to a distributed form (in the one
> call) but obviously there is more to be done. I will go back and follow
> Randy's suggestions now that I know the conversion from global to distributed
> matrices isn't as straightforward as I hoped.
> Regards,
> Tim.
> Matthew Knepley wrote:
> > On 4/24/07, Dr. Timothy Stitt <timothy.stitt at ichec.ie> wrote:
> > > Hi everyone...again.
> > > Thanks to the great support I have now got my solver working (in
> > > Fortran) albeit in a sequential non-distributed version. My problem is
> > > that I planned to substitute the call to MatCreateSeqAIJWithArrays()
> > > with a call to MatCreateMPIAIJWithArrays() (along with suitable
> > > modification to the arguments) to obtain a parallel version.
> > > Anyhow, I have come upon a few problems() unfortunately. Firstly here
> > > are the code segments I am trying to update (my sparse matrix is square
> > > with global dimensions [rows,rows], size is returned by MPI_COMM_SIZE()):
> > > call MatCreateSeqAIJWithArrays(PETSC_COMM_WORLD,rows,rows,&
> > >         csrRowPointers,csrColumnIndices,csrElements,A,ierr)
> > > TO
> > > call
> > > MatCreateMPIAIJWithArrays(PETSC_COMM_WORLD,rows/size,rows/size,rows,rows,&
> > > 1. Firstly, when I compile the code I keep getting:
> > >  solver.o(.text+0x202): In function `MAIN__':
> > > : undefined reference to `matcreatempiaijwitharrays_'
> > There is no Fortran interface for this function (since no one had ever
> > asked).
> > > 2. Do the arguments to the routine look correct ? I would prefer for
> > > PETSc to determine as many of the arguments as possible but I wasn't
> > > sure which ones to supply explicitly or allow PETSc to infer implicitly.
> > No, I think you are going to have some problems here. This function is
> > intended
> > for people who already have a parallel CSR matrix constructed. From your
> > discussion above, this does not appear to be the case. I see several
> > pitfalls:
> >  a) size may not evenly divide rows
> >  b) the arrays must be only for rows local to the process, but contain
> > global
> >      indices
> > I would encourage you to follow the steps that Randy outlined, namely create
> > the matrix (letting PETSc partition the rows), preallocate the storage by
> > determining local row lengths, and the setting values with MatSetValues for
> > each row.
> >  Thanks,
> >     Matt
> > > 3. When constructing the operator matrix is it o.k. to build it only on
> > > node with rank 0 or does it have to be duplicated across all nodes
> > > before the call to the MatCreateMPIxxxxx() routine? The matrix is very
> > > large and hence wouldn't be suitable for replication.
> > > I hope this is the last of my worries. Thanks again for your support and
> > > patience.
> > > Regards,
> > > Tim.
> > > Satish Balay wrote:
> > > > On Mon, 23 Apr 2007, Satish Balay wrote:
> > > >> On Mon, 23 Apr 2007, Dr. Timothy Stitt wrote:
> > > >>> I am using Fortran. Do I have to perform some operation to switch
> > > >>> from column-major to row-major representation before calling the
> > > >>> MatCreateSeqAIJWithArrays routine?
> > > >> MatCreateSeqAIJWithArrays expects a 1d array for the values [and
> > > >> rows,column indicies as well] - so this issue of row-major vs
> > > >> column-major does not exist.
> > > > However the CSR format which is used for the input, is equivalent to a
> > > > row-major ordering.. i.e for the following matrix:
> > > > 1 0 0
> > > > 2 0 3
> > > > 0 4 5
> > > > The call expects the following
> > > > i =  {0,1,3,5}  [size = nrow+1  = 3+1]
> > > > j =  {0,0,2,1,2}  [size = nz = 5]
> > > > v =  {1,2,3,4,5}  [size = nz = 5]
> > > > Satish
> > > Dr. Timothy Stitt <timothy_dot_stitt_at_ichec.ie>
> > > HPC Application Consultant - ICHEC (www.ichec.ie)
> > > Dublin Institute for Advanced Studies
> > > 5 Merrion Square - Dublin 2 - Ireland
> > > +353-1-6621333 (tel) / +353-1-6621477 (fax) / +353-874195427 (mobile)
