CSR Sparse Matrix Query
Dr. Timothy Stitt timothy.stitt at ichec.ie
Tue Apr 24 07:39:12 CDT 2007
Matt,
Thanks for the reply. I was hoping that there was some sort of automatic
distribution from the global operator matrix to a distributed form (in
the one call) but obviously there is more to be done. I will go back and
follow Randy's suggestions now that I know the conversion from global to
distributed matrices isn't as straightforward as I hoped.
Tim.
Matthew Knepley wrote:
> On 4/24/07, Dr. Timothy Stitt <timothy.stitt at ichec.ie> wrote:
>> Hi everyone...again.
>> Thanks to the great support I have now got my solver working (in
>> Fortran) albeit in a sequential non-distributed version. My problem is
>> that I planned to substitute the call to MatCreateSeqAIJWithArrays()
>> with a call to MatCreateMPIAIJWithArrays() (along with suitable
>> modification to the arguments) to obtain a parallel version.
>> Anyhow, I have come upon a few problems() unfortunately. Firstly here
>> are the code segments I am trying to update (my sparse matrix is square
>> with global dimensions [rows,rows], size is returned by
>> MPI_COMM_SIZE()):
>> call MatCreateSeqAIJWithArrays(PETSC_COMM_WORLD,rows,rows,&
>>         csrRowPointers,csrColumnIndices,csrElements,A,ierr)
>> TO
>> call
>> MatCreateMPIAIJWithArrays(PETSC_COMM_WORLD,rows/size,rows/size,rows,rows,&
>> 1. Firstly, when I compile the code I keep getting:
>>  solver.o(.text+0x202): In function `MAIN__':
>> : undefined reference to `matcreatempiaijwitharrays_'
> There is no Fortran interface for this function (since no one had ever
> asked).
>> 2. Do the arguments to the routine look correct ? I would prefer for
>> PETSc to determine as many of the arguments as possible but I wasn't
>> sure which ones to supply explicitly or allow PETSc to infer implicitly.
> No, I think you are going to have some problems here. This function is
> intended
> for people who already have a parallel CSR matrix constructed. From your
> discussion above, this does not appear to be the case. I see several
> pitfalls:
>  a) size may not evenly divide rows
>  b) the arrays must be only for rows local to the process, but contain
> global
>      indices
> I would encourage you to follow the steps that Randy outlined, namely
> create
> the matrix (letting PETSc partition the rows), preallocate the storage by
> determining local row lengths, and the setting values with
> MatSetValues for
> each row.
>  Thanks,
>     Matt
>> 3. When constructing the operator matrix is it o.k. to build it only on
>> node with rank 0 or does it have to be duplicated across all nodes
>> before the call to the MatCreateMPIxxxxx() routine? The matrix is very
>> large and hence wouldn't be suitable for replication.
>> I hope this is the last of my worries. Thanks again for your support and
>> patience.
>> Regards,
>> Tim.
>> Satish Balay wrote:
>> > On Mon, 23 Apr 2007, Satish Balay wrote:
>> >> On Mon, 23 Apr 2007, Dr. Timothy Stitt wrote:
>> >>> I am using Fortran. Do I have to perform some operation to switch
>> >>> from column-major to row-major representation before calling the
>> >>> MatCreateSeqAIJWithArrays routine?
>> >> MatCreateSeqAIJWithArrays expects a 1d array for the values [and
>> >> rows,column indicies as well] - so this issue of row-major vs
>> >> column-major does not exist.
>> > However the CSR format which is used for the input, is equivalent to a
>> > row-major ordering.. i.e for the following matrix:
>> > 1 0 0
>> > 2 0 3
>> > 0 4 5
>> > The call expects the following
>> > i =  {0,1,3,5}  [size = nrow+1  = 3+1]
>> > j =  {0,0,2,1,2}  [size = nz = 5]
>> > v =  {1,2,3,4,5}  [size = nz = 5]
>> > Satish
>> Dr. Timothy Stitt <timothy_dot_stitt_at_ichec.ie>
>> HPC Application Consultant - ICHEC (www.ichec.ie)
>> Dublin Institute for Advanced Studies
>> 5 Merrion Square - Dublin 2 - Ireland
>> +353-1-6621333 (tel) / +353-1-6621477 (fax) / +353-874195427 (mobile)
