HYPRE with multiple variables
Shaman Mahmoudi shma7099 at student.uu.se
Fri Apr 13 07:13:23 CDT 2007
int HYPRE_BoomerAMGSetNumFunctions (.....)
sets the size of the system of PDEs.
With best regards, Shaman Mahmoudi
On Apr 13, 2007, at 2:04 PM, Shaman Mahmoudi wrote:
> Hi Nicolas,
> You are right. hypre has changed a lot since the version I used.
> I found this interesting information:
> int HYPRE_BOOMERAMGSetNodal(....)
> Sets whether to use the nodal systems version. Default is 0.
> Then information about smoothers:
> One interesting thing there is this,
> HYPRE_BoomerAMGSetDomainType(....)
> 0 - each point is a domain (default)
> 1 each node is a domain (only of interest in systems AMG)
> 2 ....
> I could not find how you define the nodal displacement ordering.
> But it should be there somewhere.
> I read the reference manual for hypre 2.0
> On Apr 13, 2007, at 1:40 PM, Nicolas Bathfield wrote:
>> Dear Shaman,
>> As far as I could understand, there is a BoomerAMG’s systems AMG
>> version
>> available. This seems to be exactly what I am looking for, but I just
>> don't know how to access it, either through PETSc or directly.
>> Best regards,
>> Nicolas
>>> Hi,
>>> You want to exploit the structure of the model?
>>> As far as I know, boomeramg can not treat a set of rows or blocks as
>>> a molecule,  a so called block-smoother?
>>> ML 2.0 smoothed aggregation does support it.
>>> On Apr 13, 2007, at 10:45 AM, Nicolas Bathfield wrote:
>>>> Hi,
>>>> I am solving the Navier-stokes equations and try to use Hypre as
>>>> preconditioner.
>>>> Until now, I used PETSc as non-segregated solver and it worked
>>>> perfectly.
>>>> Things got worse when I decided to use Boomeramg (Hypre).
>>>> As I solve a system of PDEs,  each cell is represented by 5 rows
>>>> in my
>>>> matrix (I solve for 5 variables). PETSc handles that without
>>>> problem
>>>> apparently, but the coarsening scheme of Boomeramg needs more
>>>> input in
>>>> order to work properly.
>>>> Is there an option in PETSc to tell HYPRE that we are dealing
>>>> with a
>>>> system of PDEs? (something like:  -pc_hypre_boomeramg_...)
>>>> Thanks for your help.
>>>> Best regards,
>>>> Nicolas
>>>> Nicolas BATHFIELD
>>>> Chalmers University of Technology
>>>> Shipping and Marine Technology
>>>> phone: +46 (0)31 772 1476
>>>> fax:   +46 (0)31 772 3699
>> Nicolas BATHFIELD
