HYPRE with multiple variables
Shaman Mahmoudi shma7099 at student.uu.se
Fri Apr 13 07:04:50 CDT 2007
Hi Nicolas,
You are right. hypre has changed a lot since the version I used.
I found this interesting information:
int HYPRE_BOOMERAMGSetNodal(....)
Sets whether to use the nodal systems version. Default is 0.
Then information about smoothers:
One interesting thing there is this,
HYPRE_BoomerAMGSetDomainType(....)
0 - each point is a domain (default)
1 each node is a domain (only of interest in systems AMG)
2 ....
I could not find how you define the nodal displacement ordering. But
it should be there somewhere.
I read the reference manual for hypre 2.0
With best regards, Shaman Mahmoudi
On Apr 13, 2007, at 1:40 PM, Nicolas Bathfield wrote:
> Dear Shaman,
> As far as I could understand, there is a BoomerAMG’s systems AMG
> version
> available. This seems to be exactly what I am looking for, but I just
> don't know how to access it, either through PETSc or directly.
> Best regards,
> Nicolas
>> Hi,
>> You want to exploit the structure of the model?
>> As far as I know, boomeramg can not treat a set of rows or blocks as
>> a molecule,  a so called block-smoother?
>> ML 2.0 smoothed aggregation does support it.
>> On Apr 13, 2007, at 10:45 AM, Nicolas Bathfield wrote:
>>> Hi,
>>> I am solving the Navier-stokes equations and try to use Hypre as
>>> preconditioner.
>>> Until now, I used PETSc as non-segregated solver and it worked
>>> perfectly.
>>> Things got worse when I decided to use Boomeramg (Hypre).
>>> As I solve a system of PDEs,  each cell is represented by 5 rows
>>> in my
>>> matrix (I solve for 5 variables). PETSc handles that without problem
>>> apparently, but the coarsening scheme of Boomeramg needs more
>>> input in
>>> order to work properly.
>>> Is there an option in PETSc to tell HYPRE that we are dealing with a
>>> system of PDEs? (something like:  -pc_hypre_boomeramg_...)
>>> Thanks for your help.
>>> Best regards,
>>> Nicolas
>>> Nicolas BATHFIELD
>>> Chalmers University of Technology
>>> Shipping and Marine Technology
>>> phone: +46 (0)31 772 1476
>>> fax:   +46 (0)31 772 3699
> Nicolas BATHFIELD
