ld: skipping incompatible
Thu Apr 12 08:13:00 CDT 2007
It is not using these 32-bit libraries that someone, probably your compiler for
some reason, reported to configure. If everything runs, you are fine.
   Matt
On 4/12/07, Ben Tay <zonexo at gmail.com> wrote:
> Hi,
> i've just compiled PETSc on a 64bit system. No error was shown. However,
> when using make ex1f (or other similar compilation), I got this error msg:
> /usr/lib/gcc/x86_64-redhat-linux/3.4.6/../../../libnsl.so
> when searching for -lnsl
> /usr/lib/gcc/x86_64-redhat-linux/3.4.6/../../../libnsl.a
> /usr/lib/gcc/x86_64-redhat-linux/3.4.6/../../../librt.so
> when searching for -lrt
> /usr/lib/gcc/x86_64-redhat-linux/3.4.6/../../../librt.a
> /usr/lib/gcc/x86_64-redhat-linux/3.4.6/../../../libdl.so
> when searching for -ldl
> /usr/lib/gcc/x86_64-redhat-linux/3.4.6/../../../libdl.a
> /usr/lib/gcc/x86_64-redhat-linux/3.4.6/../../../libm.so
> when searching for -lm
> /usr/lib/gcc/x86_64-redhat-linux/3.4.6/../../../libm.a when
> searching for -lm
> searching for -lm
> searching for -lm
> /usr/lib/gcc/x86_64-redhat-linux/3.4.6/../../../libc.so
> when searching for -lc
> /usr/lib/gcc/x86_64-redhat-linux/3.4.6/../../../libc.a when
> searching for -lc
> searching for -lc
> The test file worked fine, same as some of my test codes. But i'm not sure
> if there 'll be problems in the future.
> Is this a serious problem? How can I fix it. Thanks.
The government saving money is like me spilling beer. It happens, but
never on purpose.
