ld: skipping incompatible
Ben Tay zonexo at gmail.com
Thu Apr 12 08:09:55 CDT 2007
i've just compiled PETSc on a 64bit system. No error was shown. However,
when using make ex1f (or other similar compilation), I got this error msg:
/usr/lib/gcc/x86_64-redhat-linux/3.4.6/../../../libnsl.so when searching for
-lnsl
/usr/lib/gcc/x86_64-redhat-linux/3.4.6/../../../libnsl.a when searching for
-lnsl
/usr/lib/gcc/x86_64-redhat-linux/3.4.6/../../../librt.so when searching for
-lrt
/usr/lib/gcc/x86_64-redhat-linux/3.4.6/../../../librt.a when searching for
-lrt
/usr/lib/gcc/x86_64-redhat-linux/3.4.6/../../../libdl.so when searching for
-ldl
/usr/lib/gcc/x86_64-redhat-linux/3.4.6/../../../libdl.a when searching for
-ldl
/usr/lib/gcc/x86_64-redhat-linux/3.4.6/../../../libm.so when searching for
-lm
/usr/lib/gcc/x86_64-redhat-linux/3.4.6/../../../libm.a when searching for
-lm
-lm
-lm
-ldl
-ldl
-ldl
-ldl
-lm
-lm
/usr/lib/gcc/x86_64-redhat-linux/3.4.6/../../../libc.so when searching for
-lc
/usr/lib/gcc/x86_64-redhat-linux/3.4.6/../../../libc.a when searching for
-lc
-ldl
-ldl
-lc
-lc
The test file worked fine, same as some of my test codes. But i'm not sure
if there 'll be problems in the future.
Is this a serious problem? How can I fix it. Thanks.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20070412/412d2fa8/attachment.htm>
