unable to find include files during make
Ben Tay zonexo at gmail.com
Wed Nov 29 21:35:23 CST 2006
hi,
i've managed to compile petsc on my sch's linux server. i've done both the
shared and non-shared libraries. test examples worked fine. however when i
tried to compile my own code which uses petsc in one of the module, it says
"can't find include file..... (all include files)".
my petsc_dir/petsc arch has already been set. i'm using intel fortran 7
(ifc) with gcc, because i get the error msg "Fortran libraries cannot be
used with C compiler" when i tried ifc with icc. is there anyway to get
around this?
anyway, how should my makefile be? currently my makefile for the petsc
solver is
petsc_sub.o : petsc_sub.F
        $(f90) $(opt) petsc_sub.F
if i compiled as shared libraries, what other statements must i add? the
current opt are
  -r8 -ip -w95 -c -static-libcxa -L/nas/lsftmp/g0306332/petsc-2.3.2-p6/
thank you very much
regards
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20061130/cc0007d5/attachment.htm>
