Modifying the MSDdev *.dsw *.dsp files to run without mpi
Ben Tay zonexo at gmail.com
Fri Nov 24 19:42:11 CST 2006
yes I did that. There is no problem if I run the example in cygwin. However,
if I use the project files for MSDev given in the petsc package, it gives me
errors during linking. Compiling works though.
I tried to recompile the whole Petsc with mpich1 and there is no such
errors.
Thank you.
On 11/25/06, Matthew Knepley <knepley at gmail.com> wrote:
> You need to configure using --wih-mpi=0.
> Matt
> On 11/24/06, Ben Tay <zonexo at gmail.com> wrote:
> > Hi,
> > I've managed to compile and run the examples in MSDev when i use MPICH.
> > However, if I compile without MPI, I 'll get errors during linking. How
> > should I modify my configuration file in MSDev so that I can run without
> > mpi?
> > Thank you very much!
> "Failure has a thousand explanations. Success doesn't need one" -- Sir
> Alec Guiness
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20061125/030505d6/attachment.htm>
