Modifying the MSDdev *.dsw *.dsp files to run without mpi
Fri Nov 24 19:05:22 CST 2006
You need to configure using --wih-mpi=0.
  Matt
On 11/24/06, Ben Tay <zonexo at gmail.com> wrote:
> Hi,
> I've managed to compile and run the examples in MSDev when i use MPICH.
> However, if I compile without MPI, I 'll get errors during linking. How
> should I modify my configuration file in MSDev so that I can run without
> mpi?
> Thank you very much!
"Failure has a thousand explanations. Success doesn't need one" -- Sir
Alec Guiness
